[petsc-users] [petsc-maint] DMSwarm on multiple processors
Wed Oct 25 07:45:38 CDT 2023
On Wed, Oct 25, 2023 at 8:32 AM Joauma Marichal via petsc-maint <
petsc-maint at mcs.anl.gov> wrote:
> Hello,
> I am using the DMSwarm library in some Eulerian-Lagrangian approach to
> have vapor bubbles in water.
> I have obtained nice results recently and wanted to perform bigger
> simulations. Unfortunately, when I increase the number of processors used
> to run the simulation, I get the following error:
> free(): invalid size
> [cns136:590327] *** Process received signal ***
> [cns136:590327] Signal: Aborted (6)
> [cns136:590327] Signal code:  (-6)
> [cns136:590327] [ 0] /lib64/libc.so.6(+0x4eb20)[0x7f56cd4c9b20]
> [cns136:590327] [ 1] /lib64/libc.so.6(gsignal+0x10f)[0x7f56cd4c9a9f]
> [cns136:590327] [ 2] /lib64/libc.so.6(abort+0x127)[0x7f56cd49ce05]
> [cns136:590327] [ 3] /lib64/libc.so.6(+0x91037)[0x7f56cd50c037]
> [cns136:590327] [ 4] /lib64/libc.so.6(+0x9819c)[0x7f56cd51319c]
> [cns136:590327] [ 5] /lib64/libc.so.6(+0x99aac)[0x7f56cd514aac]
> [cns136:590327] [ 6]
> /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(PetscSFSetUpRanks+0x4c4)[0x7f56cea71e64]
> [cns136:590327] [ 7]
> /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(+0x841642)[0x7f56cea83642]
> [cns136:590327] [ 8]
> /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(PetscSFSetUp+0x9e)[0x7f56cea7043e]
> [cns136:590327] [ 9]
> /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(VecScatterCreate+0x164e)[0x7f56cea7bbde]
> [cns136:590327] [10]
> /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(DMSetUp_DA_3D+0x3e38)[0x7f56cee84dd8]
> [cns136:590327] [11]
> /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(DMSetUp_DA+0xd8)[0x7f56cee9b448]
> [cns136:590327] [12]
> /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(DMSetUp+0x20)[0x7f56cededa20]
> [cns136:590327] [13] ./cobpor[0x4418dc]
> [cns136:590327] [14] ./cobpor[0x408b63]
> [cns136:590327] [15]
> /lib64/libc.so.6(__libc_start_main+0xf3)[0x7f56cd4b5cf3]
> [cns136:590327] [16] ./cobpor[0x40bdee]
> [cns136:590327] *** End of error message ***
> Primary job  terminated normally, but 1 process returned
> a non-zero exit code. Per user-direction, the job has been aborted.
> mpiexec noticed that process rank 84 with PID 590327 on node cns136 exited
> on signal 6 (Aborted).
> When I reduce the number of processors the error disappears and when I run
> my code without the vapor bubbles it also works.
> The problem seems to take place at this moment:
> DMCreate(PETSC_COMM_WORLD,swarm);
>     DMSetType(*swarm,DMSWARM);
>     DMSetDimension(*swarm,3);
>     DMSwarmSetType(*swarm,DMSWARM_PIC);
>     DMSwarmSetCellDM(*swarm,*dmcell);
> Thanks a lot for your help.
Things that would help us track this down:
1) The smallest example where it fails
2) The smallest number of processes where it fails
3) A stack trace of the failure
4) A simple example that we can run that also fails
     Matt
> Best regards,
> Joauma
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231025/e53e7f96/attachment.html>
