[petsc-users] Scalability problem using PETSc with local installed OpenMPI
Barry Smith
bsmith at petsc.dev
Tue Oct 10 08:59:53 CDT 2023
Take a look at https://petsc.org/release/faq/#what-kind-of-parallel-computers-or-clusters-are-needed-to-use-petsc-or-why-do-i-get-little-speedup
Check the binding that OpenMPI is using (by the way, there are much more recent OpenMPI versions, I suggest using them). Run the STREAMS benchmark as indicated on that page.
Barry
> On Oct 10, 2023, at 9:27 AM, Gong Yujie <yc17470 at connect.um.edu.mo> wrote:
> Dear PETSc developers,
> I installed OpenMPI3 first and then installed PETSc with that mpi. Currently, I'm facing a scalability issue, in detail, I tested that using OpenMPI to calculate an addition of two distributed arrays and I get a good scalability. The problem is when I calculate the addition of two vectors in PETSc, I don't have any scalability. For the same size of the problem, PETSc costs a lot much time than merely using OpenMPI.
> My PETSc version is 3.16.0 and the version of OpenMPI is 3.1.4. Hope you can give me some suggestions.
> Best Regards,
> Yujie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231010/7711a60c/attachment-0001.html>
