[petsc-users] Scalability problem using PETSc with local installed OpenMPI
Matthew Knepley
knepley at gmail.com
Tue Oct 10 08:54:27 CDT 2023
On Tue, Oct 10, 2023 at 9:28 AM Gong Yujie <yc17470 at connect.um.edu.mo>
wrote:
> Dear PETSc developers,
> I installed OpenMPI3 first and then installed PETSc with that mpi.
> Currently, I'm facing a scalability issue, in detail, I tested that using
> OpenMPI to calculate an addition of two distributed arrays and I get a good
> scalability. The problem is when I calculate the addition of two vectors in
> PETSc, I don't have any scalability. For the same size of the problem,
> PETSc costs a lot much time than merely using OpenMPI.
> My PETSc version is 3.16.0 and the version of OpenMPI is 3.1.4. Hope you
> can give me some suggestions.
1. For any performance question, we really need to see the output of
-log_view for each run.
2. I am not sure I understand your question. Vector addition does not
involve communication. Thus it will scale perfectly in the absence of load
imbalance.
Matt
> Best Regards,
> Yujie
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231010/d97fdb34/attachment.html>
