[petsc-users] MPI barrier issue using MatZeroRows
    Amneet Bhalla
    mail2amneet at gmail.com
    Wed Nov 29 21:11:03 CST 2023
Awesome! MatZeroRows is very useful and simplified the code logic.
On Wed, Nov 29, 2023 at 5:14 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Nov 29, 2023 at 7:27 PM Amneet Bhalla <mail2amneet at gmail.com>
> wrote:
>> Ah, I also tried without step 2 (i.e., manually doing MPI_allgatherv for
>> Dirichlet rows), and that also works. So it seems that each processor needs
>> to send in their own Dirichlet rows, and not a union of them. Is that
>> correct?
> Yes, that is correct.
>   Thanks,
>     Matt
>> On Wed, Nov 29, 2023 at 3:48 PM Amneet Bhalla <mail2amneet at gmail.com>
>> wrote:
>>> Thanks Barry! I tried that and it seems to be working. This is what I
>>> did. It would be great if you could take a look at it and let me know if
>>> this is what you had in mind.
>>> 1. Collected Dirichlet rows locally
>>> https://github.com/IBAMR/IBAMR/blob/amneetb/acoustically-driven-flows/src/acoustic_streaming/AcousticStreamingPETScMatUtilities.cpp#L731
>>> https://github.com/IBAMR/IBAMR/blob/amneetb/acoustically-driven-flows/src/acoustic_streaming/AcousticStreamingPETScMatUtilities.cpp#L797
>>> 2. MPI_allgatherv Dirichlet rows
>>> https://github.com/IBAMR/IBAMR/blob/amneetb/acoustically-driven-flows/src/acoustic_streaming/AcousticStreamingPETScMatUtilities.cpp#L805-L810
>>> 3. Called the MatZeroRows function
>>> https://github.com/IBAMR/IBAMR/blob/amneetb/acoustically-driven-flows/src/acoustic_streaming/AcousticStreamingPETScMatUtilities.cpp#L812-L814
>>> On Wed, Nov 29, 2023 at 11:32 AM Barry Smith <bsmith at petsc.dev> wrote:
>>>> On Nov 29, 2023, at 2:11 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Wed, Nov 29, 2023 at 1:55 PM Amneet Bhalla <mail2amneet at gmail.com>
>>>> wrote:
>>>>> So the code logic is after the matrix is assembled, I iterate over all
>>>>> distributed patches in the domain to see which of the patch is abutting a
>>>>> Dirichlet boundary. Depending upon which patch abuts a physical and
>>>>> Dirichlet boundary, a processor will call this routine. However, that same
>>>>> processor is “owning” that DoF, which would be on its diagonal.
>>>>> I think Barry already mentioned this is not going to work unless I use
>>>>> the flag to not communicate explicitly. However, that flag is not working
>>>>> as it should over here for some reason.
>>>> Oh, I do not think that is right.
>>>> Barry, when I look at the code, MPIU_Allreduce is always going to be
>>>> called to fix up the nonzero_state. Am I wrong about that?
>>>>   No, you are correct. I missed that in my earlier look. Setting those
>>>> flags reduce the number of MPI reductions but does not eliminate them
>>>> completely.
>>>>   MatZeroRows is collective (as its manual page indicates) so you have
>>>> to do the second thing I suggested. Inside your for loop construct an array
>>>> containing all the local
>>>> rows being zeroed and then make a single call by all MPI processes to
>>>> MatZeroRows().  Note this is a small change of just a handful of lines of
>>>> code.
>>>>    Barry
>>>>   Thanks,
>>>>     Matt
>>>>> I can always change the matrix coefficients for Dirichlet rows during
>>>>> MatSetValues. However, that would lengthen my code and I was trying to
>>>>> avoid that.
>>>>> On Wed, Nov 29, 2023 at 10:02 AM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Wed, Nov 29, 2023 at 12:30 PM Amneet Bhalla <mail2amneet at gmail.com>
>>>>>> wrote:
>>>>>>> Ok, I added both, but it still hangs. Here, is bt from all three
>>>>>>> tasks:
>>>>>> It looks like two processes are calling AllReduce, but one is not.
>>>>>> Are all procs not calling MatZeroRows?
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Task 1:
>>>>>>> amneetb at APSB-MacBook-Pro-16:~$ lldb  -p 44691
>>>>>>> (lldb) process attach --pid 44691
>>>>>>> Process 44691 stopped
>>>>>>> * thread #1, queue = 'com.apple.main-thread', stop reason = signal
>>>>>>> SIGSTOP
>>>>>>>     frame #0: 0x000000018a2d750c
>>>>>>> libsystem_kernel.dylib`__semwait_signal + 8
>>>>>>> libsystem_kernel.dylib`:
>>>>>>> ->  0x18a2d750c <+8>:  b.lo   0x18a2d752c               ; <+40>
>>>>>>>     0x18a2d7510 <+12>: pacibsp
>>>>>>>     0x18a2d7514 <+16>: stp    x29, x30, [sp, #-0x10]!
>>>>>>>     0x18a2d7518 <+20>: mov    x29, sp
>>>>>>> Target 0: (fo_acoustic_streaming_solver_2d) stopped.
>>>>>>> Executable module set to
>>>>>>> "/Users/amneetb/Softwares/IBAMR-Git/objs-dbg/tests/IBTK/fo_acoustic_streaming_solver_2d".
>>>>>>> Architecture set to: arm64-apple-macosx-.
>>>>>>> (lldb) cont
>>>>>>> Process 44691 resuming
>>>>>>> SIGSTOP
>>>>>>>     frame #0: 0x000000010ba40b60
>>>>>>> libpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_release + 752
>>>>>>> libpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_release:
>>>>>>> ->  0x10ba40b60 <+752>: add    w8, w8, #0x1
>>>>>>>     0x10ba40b64 <+756>: ldr    w9, [x22]
>>>>>>>     0x10ba40b68 <+760>: cmp    w8, w9
>>>>>>>     0x10ba40b6c <+764>: b.lt   0x10ba40b4c               ; <+732>
>>>>>>> (lldb) bt
>>>>>>> SIGSTOP
>>>>>>>   * frame #0: 0x000000010ba40b60
>>>>>>>     frame #1: 0x000000010ba48528
>>>>>>> libpmpi.12.dylib`MPIDI_POSIX_mpi_allreduce_release_gather + 1088
>>>>>>>     frame #2: 0x000000010ba47964
>>>>>>> libpmpi.12.dylib`MPIDI_Allreduce_intra_composition_gamma + 368
>>>>>>>     frame #3: 0x000000010ba35e78 libpmpi.12.dylib`MPIR_Allreduce +
>>>>>>> 1588
>>>>>>>     frame #4: 0x0000000103f587dc libmpi.12.dylib`MPI_Allreduce +
>>>>>>> 2280
>>>>>>>     frame #5: 0x0000000106d67650
>>>>>>> libpetsc.3.17.dylib`MatZeroRows_MPIAIJ(A=0x0000000105846470, N=1,
>>>>>>> rows=0x000000016dbfa9f4, diag=1, x=0x0000000000000000,
>>>>>>> b=0x0000000000000000) at mpiaij.c:827:3
>>>>>>>     frame #6: 0x0000000106aadfac
>>>>>>> libpetsc.3.17.dylib`MatZeroRows(mat=0x0000000105846470, numRows=1,
>>>>>>> b=0x0000000000000000) at matrix.c:5935:3
>>>>>>>     frame #7: 0x00000001023952d0
>>>>>>> fo_acoustic_streaming_solver_2d`IBAMR::AcousticStreamingPETScMatUtilities::constructPatchLevelFOAcousticStreamingOp(mat=0x000000016dc04168,
>>>>>>> omega=1, sound_speed=1, rho_idx=3, mu_idx=2, lambda_idx=4,
>>>>>>> u_bc_coefs=0x000000016dc04398, data_time=NaN, num_dofs_per_proc=size=3,
>>>>>>> u_dof_index_idx=27, p_dof_index_idx=28,
>>>>>>> patch_level=Pointer<SAMRAI::hier::PatchLevel<2> > @ 0x000000016dbfcec0,
>>>>>>> mu_interp_type=VC_HARMONIC_INTERP) at
>>>>>>> AcousticStreamingPETScMatUtilities.cpp:799:36
>>>>>>>     frame #8: 0x00000001023acb8c
>>>>>>> fo_acoustic_streaming_solver_2d`IBAMR::FOAcousticStreamingPETScLevelSolver::initializeSolverStateSpecialized(this=0x000000016dc04018,
>>>>>>> x=0x000000016dc05778, (null)=0x000000016dc05680) at
>>>>>>> FOAcousticStreamingPETScLevelSolver.cpp:149:5
>>>>>>>     frame #9: 0x000000010254a2dc
>>>>>>> fo_acoustic_streaming_solver_2d`IBTK::PETScLevelSolver::initializeSolverState(this=0x000000016dc04018,
>>>>>>> x=0x000000016dc05778, b=0x000000016dc05680) at PETScLevelSolver.cpp:
>>>>>>> 340:5
>>>>>>>     frame #10: 0x0000000102202e5c
>>>>>>> fo_acoustic_streaming_solver_2d`main(argc=11, argv=0x000000016dc07450) at
>>>>>>> fo_acoustic_streaming_solver.cpp:400:22
>>>>>>>     frame #11: 0x0000000189fbbf28 dyld`start + 2236
>>>>>>> (lldb)
>>>>>>> Task 2:
>>>>>>> amneetb at APSB-MacBook-Pro-16:~$ lldb  -p 44692
>>>>>>> (lldb) process attach --pid 44692
>>>>>>> Process 44692 stopped
>>>>>>> SIGSTOP
>>>>>>> (lldb) cont
>>>>>>> Process 44692 resuming
>>>>>>> SIGSTOP
>>>>>>>     frame #0: 0x000000010e5a022c
>>>>>>> libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather + 516
>>>>>>> libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather:
>>>>>>> ->  0x10e5a022c <+516>: ldr    x10, [x19, #0x4e8]
>>>>>>>     0x10e5a0230 <+520>: cmp    x9, x10
>>>>>>>     0x10e5a0234 <+524>: b.hs   0x10e5a0254               ; <+556>
>>>>>>>     0x10e5a0238 <+528>: add    w8, w8, #0x1
>>>>>>> (lldb) bt
>>>>>>> SIGSTOP
>>>>>>>   * frame #0: 0x000000010e5a022c
>>>>>>>     frame #1: 0x000000010e59fd14
>>>>>>> libpmpi.12.dylib`MPIDI_SHM_mpi_barrier + 224
>>>>>>>     frame #2: 0x000000010e59fb60
>>>>>>> libpmpi.12.dylib`MPIDI_Barrier_intra_composition_alpha + 44
>>>>>>>     frame #3: 0x000000010e585490 libpmpi.12.dylib`MPIR_Barrier + 900
>>>>>>>     frame #4: 0x0000000106ac5030 libmpi.12.dylib`MPI_Barrier + 684
>>>>>>>     frame #5: 0x0000000108e62638
>>>>>>> libpetsc.3.17.dylib`PetscCommDuplicate(comm_in=1140850688,
>>>>>>> comm_out=0x00000001408ae4b0, first_tag=0x00000001408ae4e4) at tagm.c
>>>>>>> :235:5
>>>>>>>     frame #6: 0x0000000108e6a910
>>>>>>> libpetsc.3.17.dylib`PetscHeaderCreate_Private(h=0x00000001408ae470,
>>>>>>> classid=1211228, class_name="KSP", descr="Krylov Method", mansec="KSP",
>>>>>>> comm=1140850688, destroy=(libpetsc.3.17.dylib`KSPDestroy at itfunc.c:1418),
>>>>>>> view=(libpetsc.3.17.dylib`KSPView at itcreate.c:113)) at inherit.c:
>>>>>>> 62:3
>>>>>>>     frame #7: 0x000000010aa28010
>>>>>>> libpetsc.3.17.dylib`KSPCreate(comm=1140850688, inksp=0x000000016b0a4160) at
>>>>>>> itcreate.c:679:3
>>>>>>>     frame #8: 0x00000001050aa2f4
>>>>>>> fo_acoustic_streaming_solver_2d`IBTK::PETScLevelSolver::initializeSolverState(this=0x000000016b0a4018,
>>>>>>> x=0x000000016b0a5778, b=0x000000016b0a5680) at PETScLevelSolver.cpp:
>>>>>>> 344:12
>>>>>>>     frame #9: 0x0000000104d62e5c
>>>>>>> fo_acoustic_streaming_solver_2d`main(argc=11, argv=0x000000016b0a7450) at
>>>>>>>     frame #10: 0x0000000189fbbf28 dyld`start + 2236
>>>>>>> (lldb)
>>>>>>> Task 3:
>>>>>>> amneetb at APSB-MacBook-Pro-16:~$ lldb  -p 44693
>>>>>>> (lldb) process attach --pid 44693
>>>>>>> Process 44693 stopped
>>>>>>> SIGSTOP
>>>>>>> (lldb) cont
>>>>>>> Process 44693 resuming
>>>>>>> SIGSTOP
>>>>>>>     frame #0: 0x000000010e59c68c
>>>>>>> libpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_gather + 952
>>>>>>> libpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_gather:
>>>>>>> ->  0x10e59c68c <+952>: ldr    w9, [x21]
>>>>>>>     0x10e59c690 <+956>: cmp    w8, w9
>>>>>>>     0x10e59c694 <+960>: b.lt   0x10e59c670               ; <+924>
>>>>>>>     0x10e59c698 <+964>: bl     0x10e59ce64               ;
>>>>>>> MPID_Progress_test
>>>>>>> (lldb) bt
>>>>>>> SIGSTOP
>>>>>>>   * frame #0: 0x000000010e59c68c
>>>>>>>     frame #1: 0x000000010e5a44bc
>>>>>>> libpmpi.12.dylib`MPIDI_POSIX_mpi_allreduce_release_gather + 980
>>>>>>>     frame #2: 0x000000010e5a3964
>>>>>>>     frame #3: 0x000000010e591e78 libpmpi.12.dylib`MPIR_Allreduce +
>>>>>>> 1588
>>>>>>>     frame #4: 0x0000000106ab47dc libmpi.12.dylib`MPI_Allreduce +
>>>>>>> 2280
>>>>>>>     frame #5: 0x00000001098c3650
>>>>>>> libpetsc.3.17.dylib`MatZeroRows_MPIAIJ(A=0x0000000136862270, N=1,
>>>>>>> rows=0x000000016b09e9f4, diag=1, x=0x0000000000000000,
>>>>>>>     frame #6: 0x0000000109609fac
>>>>>>> libpetsc.3.17.dylib`MatZeroRows(mat=0x0000000136862270, numRows=1,
>>>>>>>     frame #7: 0x0000000104ef12d0
>>>>>>> fo_acoustic_streaming_solver_2d`IBAMR::AcousticStreamingPETScMatUtilities::constructPatchLevelFOAcousticStreamingOp(mat=0x000000016b0a8168,
>>>>>>> u_bc_coefs=0x000000016b0a8398, data_time=NaN, num_dofs_per_proc=size=3,
>>>>>>> patch_level=Pointer<SAMRAI::hier::PatchLevel<2> > @ 0x000000016b0a0ec0,
>>>>>>>     frame #8: 0x0000000104f08b8c
>>>>>>> fo_acoustic_streaming_solver_2d`IBAMR::FOAcousticStreamingPETScLevelSolver::initializeSolverStateSpecialized(this=0x000000016b0a8018,
>>>>>>> x=0x000000016b0a9778, (null)=0x000000016b0a9680) at
>>>>>>>     frame #9: 0x00000001050a62dc
>>>>>>> fo_acoustic_streaming_solver_2d`IBTK::PETScLevelSolver::initializeSolverState(this=0x000000016b0a8018,
>>>>>>> x=0x000000016b0a9778, b=0x000000016b0a9680) at PETScLevelSolver.cpp:
>>>>>>> 340:5
>>>>>>>     frame #10: 0x0000000104d5ee5c
>>>>>>> fo_acoustic_streaming_solver_2d`main(argc=11, argv=0x000000016b0ab450) at
>>>>>>> (lldb)
>>>>>>> On Wed, Nov 29, 2023 at 7:22 AM Barry Smith <bsmith at petsc.dev>
>>>>>>> wrote:
>>>>>>>> On Nov 29, 2023, at 1:16 AM, Amneet Bhalla <mail2amneet at gmail.com>
>>>>>>>> wrote:
>>>>>>>> BTW, I think you meant using MatSetOption(mat,
>>>>>>>> *MAT_NO_OFF_PROC_ZERO_ROWS*, PETSC_TRUE)
>>>>>>>> Yes
>>>>>>>>  instead ofMatSetOption(mat, *MAT_NO_OFF_PROC_ENTRIES*,
>>>>>>>> PETSC_TRUE) ??
>>>>>>>>   Please try setting both flags.
>>>>>>>>  However, that also did not help to overcome the MPI Barrier issue.
>>>>>>>>   If there is still a problem please trap all the MPI processes
>>>>>>>> when they hang in the debugger and send the output from using bt on all of
>>>>>>>> them. This way
>>>>>>>> we can see the different places the different MPI processes are
>>>>>>>> stuck at.
>>>>>>>> On Tue, Nov 28, 2023 at 9:57 PM Amneet Bhalla <
>>>>>>>> mail2amneet at gmail.com> wrote:
>>>>>>>>> I added that option but the code still gets stuck at the same call
>>>>>>>>> MatZeroRows with 3 processors.
>>>>>>>>> On Tue, Nov 28, 2023 at 7:23 PM Amneet Bhalla <
>>>>>>>>>> On Tue, Nov 28, 2023 at 6:42 PM Barry Smith <bsmith at petsc.dev>
>>>>>>>>>> wrote:
>>>>>>>>>>>   for (int comp = 0; comp < 2; ++comp)
>>>>>>>>>>>                     for (Box<NDIM>::Iterator bc(bc_coef_box);
>>>>>>>>>>> bc; bc++)
>>>>>>>>>>>                         if (IBTK::abs_equal_eps(b, 0.0))
>>>>>>>>>>>                             const double diag_value = a;
>>>>>>>>>>>                             ierr = MatZeroRows(mat, 1,
>>>>>>>>>>> &u_dof_index, diag_value, NULL, NULL);
>>>>>>>>>>>                             IBTK_CHKERRQ(ierr);
>>>>>>>>>>> In general, this code will not work because each process calls
>>>>>>>>>>> MatZeroRows a different number of times, so it cannot match up with all the
>>>>>>>>>>> processes.
>>>>>>>>>>> If u_dof_index is always local to the current process, you can
>>>>>>>>>>> call MatSetOption(mat, MAT_NO_OFF_PROC_ENTRIES,PETSC_TRUE) above the for
>>>>>>>>>>> loop and
>>>>>>>>>>> the MatZeroRows will not synchronize across the MPI processes
>>>>>>>>>>> (since it does not need to and you told it that).
>>>>>>>>>> Yes, u_dof_index is going to be local and I put a check on it a
>>>>>>>>>> few lines before calling MatZeroRows.
>>>>>>>>>> Can MatSetOption() be called after the matrix has been assembled?
>>>>>>>>>>> If the u_dof_index will not always be local, then you need, on
>>>>>>>>>>> each process, to list all the u_dof_index for each process in an array and
>>>>>>>>>>> then call MatZeroRows()
>>>>>>>>>>> once after the loop so it can exchange the needed information
>>>>>>>>>>> with the other MPI processes to get the row indices to the right place.
>>>>>>>>>>> Barry
>>>>>>>>>>> On Nov 28, 2023, at 6:44 PM, Amneet Bhalla <
>>>>>>>>>>> Hi Folks,
>>>>>>>>>>> I am using MatZeroRows() to set Dirichlet boundary conditions.
>>>>>>>>>>> This works fine for the serial run and the solver produces correct results
>>>>>>>>>>> (verified through analytical solution). However, when I run the case in
>>>>>>>>>>> parallel, the simulation gets stuck at MatZeroRows(). My understanding is
>>>>>>>>>>> that this function needs to be called after the MatAssemblyBegin{End}() has
>>>>>>>>>>> been called, and should be called by all processors. Here is that bit of
>>>>>>>>>>> the code which calls MatZeroRows() after the matrix has been assembled
>>>>>>>>>>> https://github.com/IBAMR/IBAMR/blob/amneetb/acoustically-driven-flows/src/acoustic_streaming/AcousticStreamingPETScMatUtilities.cpp#L724-L801
>>>>>>>>>>> I ran the parallel code (on 3 processors) in the debugger
>>>>>>>>>>> (-start_in_debugger). Below is the call stack from the processor that gets
>>>>>>>>>>> stuck
>>>>>>>>>>> amneetb at APSB-MBP-16:~$ lldb  -p 4307
>>>>>>>>>>> (lldb) process attach --pid 4307
>>>>>>>>>>> Process 4307 stopped
>>>>>>>>>>> SIGSTOP
>>>>>>>>>>> (lldb) cont
>>>>>>>>>>> Process 4307 resuming
>>>>>>>>>>> SIGSTOP
>>>>>>>>>>>     frame #0: 0x0000000109d281b8
>>>>>>>>>>> libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather + 400
>>>>>>>>>>> ->  0x109d281b8 <+400>: ldr    w9, [x24]
>>>>>>>>>>>     0x109d281bc <+404>: cmp    w8, w9
>>>>>>>>>>>     0x109d281c0 <+408>: b.lt   0x109d281a0               ;
>>>>>>>>>>> <+376>
>>>>>>>>>>>     0x109d281c4 <+412>: bl     0x109d28e64               ;
>>>>>>>>>>> MPID_Progress_test
>>>>>>>>>>> (lldb) bt
>>>>>>>>>>> SIGSTOP
>>>>>>>>>>>   * frame #0: 0x0000000109d281b8
>>>>>>>>>>>     frame #1: 0x0000000109d27d14
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231129/77bfccc5/attachment-0001.html>
