[petsc-users] DMPlex PETSCViewer for Surface Component
Mike Michell mi.mike1021 at gmail.com
Thu Mar 30 22:00:15 CDT 2023
Hi Matt, this is a follow-up to the previous question:
I have created a short code as below to create a sub-dm on the surface,
extracted from the original volume dmplex:
    call DMClone(dm_origin, dm_wall, ierr);CHKERRA(ierr)
    ! label for face sets
    call DMGetLabel(dm_wall, "Face Sets", label_facesets,
ierr);CHKERRA(ierr)
    call DMPlexLabelComplete(dm_wall, label_facesets, ierr);CHKERRA(ierr)
    ! label for vertex on surface
    call DMCreateLabel(dm_wall, "Wall", ierr);CHKERRA(ierr)
    call DMGetLabel(dm_wall, "Wall", label_surf, ierr);CHKERRA(ierr)
    call DMPlexGetChart(dm_wall, ist, iend, ierr);CHKERRA(ierr)
    do i=ist,iend
      call DMLabelGetValue(label_facesets, i, val, ierr);CHKERRA(ierr)
      if(val .eq. ID_wall) then
        call DMLabelSetValue(label_surf, i, ID_wall, ierr);CHKERRA(ierr)
      endif
    enddo
    call DMPlexLabelComplete(dm_wall, label_surf, ierr);CHKERRA(ierr)
    ! create submesh
    call DMPlexCreateSubmesh(dm_wall, label_surf, ID_wall, PETSC_TRUE,
dm_sub, ierr);CHKERRA(ierr)
    call DMPlexGetSubpointMap(dm_sub, label_sub, ierr);CHKERRA(ierr)
It is a bit unclear how to map the vector on each vertex of the original
volume dm (dm_wall) into the subdm (dm_sub). The function
DMPlexGetSubpointMap() seems to create a subpointMap (label_sub) for this
mapping, but it is hard to get an idea how to use that DMLabel for the
mapping. Shall I create DMCreateInterpolation()? But it uses Mat and Vec to
define mapping rule. Could I ask for any comments?
Mike
> Yes, you can use DMPlexCreateSubmesh() (and friends depending on exactly
> what kind of submesh you want). This will allow you to create a vector over
> only this mesh, and map your volumetric solution to that subvector. Then
> you can view the subvector (which pulls in the submesh).
>   Thanks,
>      Matt
> On Mon, Aug 1, 2022 at 10:59 PM Jed Brown <jed at jedbrown.org> wrote:
>> I would create a sub-DM containing only the part you want to view.
>> Mike Michell <mi.mike1021 at gmail.com> writes:
>> > Hi,
>> > I am a user of DMPlex object in 3D grid topology. Currently the solution
>> > field is printed out using viewer PETSCVIEWERVTK in .vtu format. By
>> doing
>> > that the entire volume components are written in the file. I was
>> wondering
>> > if there is an option that I can tell PETSc viewer to print out only
>> > surface component, instead of the entire volume.
>> > Best,
>> > Mike
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230330/ef1d80fb/attachment.html>
