[petsc-users] [EXTERNAL] Re: Kokkos backend for Mat and Vec diverging when running on CUDA device.
Fackler, Philip facklerpw at ornl.gov
Mon Mar 27 12:23:28 CDT 2023
Junchao,
I'm realizing I left you hanging in this email thread. Thank you so much for addressing the problem. I have tested it (successfully) using one process and one GPU. I'm still attempting to test with multiple GPUs (one per task) on another machine. I'll let you know if I see any more trouble.
Thanks again,
Philip Fackler
Research Software Engineer, Application Engineering Group
Advanced Computing Systems Research Section
Computer Science and Mathematics Division
Oak Ridge National Laboratory
Sent: Tuesday, February 7, 2023 16:26
To: Fackler, Philip <facklerpw at ornl.gov>
Cc: xolotl-psi-development at lists.sourceforge.net <xolotl-psi-development at lists.sourceforge.net>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; Blondel, Sophie <sblondel at utk.edu>; Roth, Philip <rothpc at ornl.gov>
Subject: Re: [EXTERNAL] Re: [petsc-users] Kokkos backend for Mat and Vec diverging when running on CUDA device.
Hi, Philip,
  I believe this MR https://gitlab.com/petsc/petsc/-/merge_requests/6030<https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgitlab.com%2Fpetsc%2Fpetsc%2F-%2Fmerge_requests%2F6030&data=05%7C01%7Cfacklerpw%40ornl.gov%7Ca70cea76b4c2430ed66508db0951f8eb%7Cdb3dbd434c4b45449f8a0553f9f5f25e%7C1%7C0%7C638114019941885806%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=%2Bg2WwdJkEBfCjsGZ0b5dEsOOFMroPS6R9VtJEnYPHZk%3D&reserved=0> would fix the problem.  It is a fix to petsc/release, but you can cherry-pick it to petsc/main.
  Could you try that in your case?
  Thanks.
--Junchao Zhang
On Fri, Jan 20, 2023 at 11:31 AM Junchao Zhang <junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>> wrote:
Sorry, no progress. I guess that is because a vector was gotten but not restored (e.g., VecRestoreArray() etc), causing host and device data not synced.  Maybe in your code, or in petsc code.
After the ECP AM, I will have more time on this bug.
Thanks.
--Junchao Zhang
On Fri, Jan 20, 2023 at 11:00 AM Fackler, Philip <facklerpw at ornl.gov<mailto:facklerpw at ornl.gov>> wrote:
Any progress on this? Any info/help needed?
Philip Fackler
From: Fackler, Philip <facklerpw at ornl.gov<mailto:facklerpw at ornl.gov>>
Sent: Thursday, December 8, 2022 09:07
To: Junchao Zhang <junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>>
Cc: xolotl-psi-development at lists.sourceforge.net<mailto:xolotl-psi-development at lists.sourceforge.net> <xolotl-psi-development at lists.sourceforge.net<mailto:xolotl-psi-development at lists.sourceforge.net>>; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>; Blondel, Sophie <sblondel at utk.edu<mailto:sblondel at utk.edu>>; Roth, Philip <rothpc at ornl.gov<mailto:rothpc at ornl.gov>>
Great! Thank you!
Philip Fackler
From: Junchao Zhang <junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>>
Sent: Wednesday, December 7, 2022 18:47
To: Fackler, Philip <facklerpw at ornl.gov<mailto:facklerpw at ornl.gov>>
Hi, Philip,
 I could reproduce the error. I need to find a  way to debug it.  Thanks.
/home/jczhang/xolotl/test/system/SystemTestCase.cpp(317): fatal error: in "System/PSI_1": absolute value of diffNorm{0.19704848134353209} exceeds 1e-10
*** 1 failure is detected in the test module "Regression"
--Junchao Zhang
On Tue, Dec 6, 2022 at 10:10 AM Fackler, Philip <facklerpw at ornl.gov<mailto:facklerpw at ornl.gov>> wrote:
I think it would be simpler to use the develop branch for this issue. But you can still just build the SystemTester. Then (if you changed the PSI_1 case) run:
 ./test/system/SystemTester -t System/PSI_1 -- -v​
(No need for multiple MPI ranks)
Philip Fackler
Sent: Monday, December 5, 2022 15:40
I configured with xolotl branch feature-petsc-kokkos, and typed `make` under ~/xolotl-build/.  Though there were errors,  a lot of *Tester were built.
[ 62%] Built target xolotlViz
[ 63%] Linking CXX executable TemperatureProfileHandlerTester
[ 64%] Linking CXX executable TemperatureGradientHandlerTester
[ 64%] Built target TemperatureProfileHandlerTester
[ 64%] Built target TemperatureConstantHandlerTester
[ 64%] Built target TemperatureGradientHandlerTester
[ 65%] Linking CXX executable HeatEquationHandlerTester
[ 65%] Built target HeatEquationHandlerTester
[ 66%] Linking CXX executable FeFitFluxHandlerTester
[ 66%] Linking CXX executable W111FitFluxHandlerTester
[ 67%] Linking CXX executable FuelFitFluxHandlerTester
[ 67%] Linking CXX executable W211FitFluxHandlerTester
Which Tester should I use to run with the parameter file benchmarks/params_system_PSI_2.txt? And how many ranks should I use?  Could you give an example command line?
Thanks.
--Junchao Zhang
On Mon, Dec 5, 2022 at 2:22 PM Junchao Zhang <junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>> wrote:
Hello, Philip,
   Do I still need to use the feature-petsc-kokkos branch?
--Junchao Zhang
On Mon, Dec 5, 2022 at 11:08 AM Fackler, Philip <facklerpw at ornl.gov<mailto:facklerpw at ornl.gov>> wrote:
Junchao,
Thank you for working on this. If you open the parameter file for, say, the PSI_2 system test case (benchmarks/params_system_PSI_2.txt), simply add -dm_mat_type aijkokkos -dm_vec_type kokkos​` to the "petscArgs=" field (or the corresponding cusparse/cuda option).
Philip Fackler
Sent: Thursday, December 1, 2022 17:05
Hi, Philip,
  Sorry for the long delay.  I could not get something useful from the -log_view output.  Since I have already built xolotl, could you give me instructions on how to do a xolotl test to reproduce the divergence with petsc GPU backends (but fine on CPU)?
  Thank you.
--Junchao Zhang
On Wed, Nov 16, 2022 at 1:38 PM Fackler, Philip <facklerpw at ornl.gov<mailto:facklerpw at ornl.gov>> wrote:
------------------------------------------------------------------ PETSc Performance Summary: ------------------------------------------------------------------
Unknown Name on a  named PC0115427 with 1 processor, by 4pf Wed Nov 16 14:36:46 2022
Using Petsc Development GIT revision: v3.18.1-115-gdca010e0e9a  GIT Date: 2022-10-28 14:39:41 +0000
                         Max       Max/Min     Avg       Total
Time (sec):           6.023e+00     1.000   6.023e+00
Objects:              1.020e+02     1.000   1.020e+02
Flops:                1.080e+09     1.000   1.080e+09  1.080e+09
Flops/sec:            1.793e+08     1.000   1.793e+08  1.793e+08
MPI Msg Count:        0.000e+00     0.000   0.000e+00  0.000e+00
MPI Msg Len (bytes):  0.000e+00     0.000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00     0.000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flop ------  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total    Count   %Total     Avg         %Total    Count   %Total
 0:      Main Stage: 6.0226e+00 100.0%  1.0799e+09 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flop: Max - maximum over all processors
                  Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   AvgLen: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flop in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
   GPU Mflop/s: 10e-6 * (sum of flop on GPU over all processors)/(max GPU time over all processors)
   CpuToGpu Count: total number of CPU to GPU copies per processor
   CpuToGpu Size (Mbytes): 10e-6 * (total size of CPU to GPU copies per processor)
   GpuToCpu Count: total number of GPU to CPU copies per processor
   GpuToCpu Size (Mbytes): 10e-6 * (total size of GPU to CPU copies per processor)
   GPU %F: percent flops on GPU in this event
Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total
   GPU    - CpuToGpu -   - GpuToCpu - GPU
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
 Mflop/s Count   Size   Count   Size  %F
--- Event Stage 0: Main Stage
BuildTwoSided          3 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
    -nan      0 0.00e+00    0 0.00e+00  0
DMCreateMat            1 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0  -nan
SFSetGraph             3 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
SFSetUp                3 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
SFPack              4647 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
SFUnpack            4647 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecDot               190 1.0   nan nan 2.11e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
    -nan      0 0.00e+00    0 0.00e+00 100
VecMDot              775 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecNorm             1728 1.0   nan nan 1.92e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0  -nan
VecScale            1983 1.0   nan nan 6.24e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  -nan
VecCopy              780 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecSet              4955 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0  -nan
VecAXPY              190 1.0   nan nan 2.11e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecAYPX              597 1.0   nan nan 6.64e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  -nan
VecAXPBYCZ           643 1.0   nan nan 1.79e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0  -nan
VecWAXPY             502 1.0   nan nan 5.58e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  -nan
VecMAXPY            1159 1.0   nan nan 3.68e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0  -nan
VecScatterBegin     4647 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0  -nan
    -nan      2 5.14e-03    0 0.00e+00  0
VecScatterEnd       4647 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecReduceArith       380 1.0   nan nan 4.23e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecReduceComm        190 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecNormalize         965 1.0   nan nan 1.61e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  -nan
TSStep                20 1.0 5.8699e+00 1.0 1.08e+09 1.0 0.0e+00 0.0e+00 0.0e+00 97100  0  0  0  97100  0  0  0   184
    -nan      2 5.14e-03    0 0.00e+00 54
TSFunctionEval       597 1.0   nan nan 6.64e+06 1.0 0.0e+00 0.0e+00 0.0e+00 63  1  0  0  0  63  1  0  0  0  -nan
    -nan      1 3.36e-04    0 0.00e+00 100
TSJacobianEval       190 1.0   nan nan 3.37e+07 1.0 0.0e+00 0.0e+00 0.0e+00 24  3  0  0  0  24  3  0  0  0  -nan
    -nan      0 0.00e+00    0 0.00e+00 97
MatMult             1930 1.0   nan nan 4.46e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1 41  0  0  0   1 41  0  0  0  -nan
MatMultTranspose       1 1.0   nan nan 3.44e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatSolve             965 1.0   nan nan 5.04e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  5  0  0  0   1  5  0  0  0  -nan
MatSOR               965 1.0   nan nan 3.33e+08 1.0 0.0e+00 0.0e+00 0.0e+00  4 31  0  0  0   4 31  0  0  0  -nan
MatLUFactorSym         1 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatLUFactorNum       190 1.0   nan nan 1.16e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1 11  0  0  0   1 11  0  0  0  -nan
MatScale             190 1.0   nan nan 3.26e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0  -nan
MatAssemblyBegin     761 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatAssemblyEnd       761 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatGetRowIJ            1 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatCreateSubMats     380 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0  -nan
MatGetOrdering         1 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatZeroEntries       379 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatSetPreallCOO        1 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatSetValuesCOO      190 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0  -nan
KSPSetUp             760 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
KSPSolve             190 1.0 5.8052e-01 1.0 9.30e+08 1.0 0.0e+00 0.0e+00 0.0e+00 10 86  0  0  0  10 86  0  0  0  1602
    -nan      1 4.80e-03    0 0.00e+00 46
KSPGMRESOrthog       775 1.0   nan nan 2.27e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0   1  2  0  0  0  -nan
SNESSolve             71 1.0 5.7117e+00 1.0 1.07e+09 1.0 0.0e+00 0.0e+00 0.0e+00 95 99  0  0  0  95 99  0  0  0   188
    -nan      1 4.80e-03    0 0.00e+00 53
SNESSetUp              1 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
SNESFunctionEval     573 1.0   nan nan 2.23e+07 1.0 0.0e+00 0.0e+00 0.0e+00 60  2  0  0  0  60  2  0  0  0  -nan
SNESJacobianEval     190 1.0   nan nan 3.37e+07 1.0 0.0e+00 0.0e+00 0.0e+00 24  3  0  0  0  24  3  0  0  0  -nan
SNESLineSearch       190 1.0   nan nan 1.05e+08 1.0 0.0e+00 0.0e+00 0.0e+00 53 10  0  0  0  53 10  0  0  0  -nan
PCSetUp              570 1.0   nan nan 1.16e+08 1.0 0.0e+00 0.0e+00 0.0e+00  2 11  0  0  0   2 11  0  0  0  -nan
PCApply              965 1.0   nan nan 6.14e+08 1.0 0.0e+00 0.0e+00 0.0e+00  8 57  0  0  0   8 57  0  0  0  -nan
    -nan      1 4.80e-03    0 0.00e+00 19
KSPSolve_FS_0        965 1.0   nan nan 3.33e+08 1.0 0.0e+00 0.0e+00 0.0e+00  4 31  0  0  0   4 31  0  0  0  -nan
KSPSolve_FS_1        965 1.0   nan nan 1.66e+08 1.0 0.0e+00 0.0e+00 0.0e+00  2 15  0  0  0   2 15  0  0  0  -nan
--- Event Stage 1: Unknown
Object Type          Creations   Destructions. Reports information only for process 0.
           Container     5              5
    Distributed Mesh     2              2
           Index Set    11             11
   IS L to G Mapping     1              1
   Star Forest Graph     7              7
     Discrete System     2              2
           Weak Form     2              2
              Vector    49             49
             TSAdapt     1              1
                  TS     1              1
                DMTS     1              1
                SNES     1              1
              DMSNES     3              3
      SNESLineSearch     1              1
       Krylov Solver     4              4
     DMKSP interface     1              1
              Matrix     4              4
      Preconditioner     4              4
              Viewer     2              1
Average time to get PetscTime(): 3.14e-08
#PETSc Option Table entries:
-log_view
-log_view_gpu_times
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with 64 bit PetscInt
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 8
Configure options: PETSC_DIR=/home/4pf/repos/petsc PETSC_ARCH=arch-kokkos-cuda-no-tpls --with-cc=mpicc --with-cxx=mpicxx --with-fc=0 --with-cuda --with-debugging=0 --with-shared-libraries --prefix=/home/4pf/build/petsc/cuda-no-tpls/install --with-64-bit-indices --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --CUDAOPTFLAGS=-O3 --with-kokkos-dir=/home/4pf/build/kokkos/cuda/install --with-kokkos-kernels-dir=/home/4pf/build/kokkos-kernels/cuda-no-tpls/install
Libraries compiled on 2022-11-01 21:01:08 on PC0115427
Machine characteristics: Linux-5.15.0-52-generic-x86_64-with-glibc2.35
Using PETSc directory: /home/4pf/build/petsc/cuda-no-tpls/install
Using PETSc arch:
Using C compiler: mpicc  -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -Wno-stringop-overflow -fstack-protector -fvisibility=hidden -O3
Using include paths: -I/home/4pf/build/petsc/cuda-no-tpls/install/include -I/home/4pf/build/kokkos-kernels/cuda-no-tpls/install/include -I/home/4pf/build/kokkos/cuda/install/include -I/usr/local/cuda-11.8/include
Using C linker: mpicc
Using libraries: -Wl,-rpath,/home/4pf/build/petsc/cuda-no-tpls/install/lib -L/home/4pf/build/petsc/cuda-no-tpls/install/lib -lpetsc -Wl,-rpath,/home/4pf/build/kokkos-kernels/cuda-no-tpls/install/lib -L/home/4pf/build/kokkos-kernels/cuda-no-tpls/install/lib -Wl,-rpath,/home/4pf/build/kokkos/cuda/install/lib -L/home/4pf/build/kokkos/cuda/install/lib -Wl,-rpath,/usr/local/cuda-11.8/lib64 -L/usr/local/cuda-11.8/lib64 -L/usr/local/cuda-11.8/lib64/stubs -lkokkoskernels -lkokkoscontainers -lkokkoscore -llapack -lblas -lm -lcudart -lnvToolsExt -lcufft -lcublas -lcusparse -lcusolver -lcurand -lcuda -lquadmath -lstdc++ -ldl
Philip Fackler
Sent: Tuesday, November 15, 2022 13:03
Can you paste -log_view result so I can see what functions are used?
--Junchao Zhang
On Tue, Nov 15, 2022 at 10:24 AM Fackler, Philip <facklerpw at ornl.gov<mailto:facklerpw at ornl.gov>> wrote:
Yes, most (but not all) of our system test cases fail with the kokkos/cuda or cuda backends. All of them pass with the CPU-only kokkos backend.
Philip Fackler
Sent: Monday, November 14, 2022 19:34
Cc: xolotl-psi-development at lists.sourceforge.net<mailto:xolotl-psi-development at lists.sourceforge.net> <xolotl-psi-development at lists.sourceforge.net<mailto:xolotl-psi-development at lists.sourceforge.net>>; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>; Blondel, Sophie <sblondel at utk.edu<mailto:sblondel at utk.edu>>; Zhang, Junchao <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>>; Roth, Philip <rothpc at ornl.gov<mailto:rothpc at ornl.gov>>
Subject: [EXTERNAL] Re: [petsc-users] Kokkos backend for Mat and Vec diverging when running on CUDA device.
Hi, Philip,
  Sorry to hear that.  It seems you could run the same code on CPUs but not no GPUs (with either petsc/Kokkos backend or petsc/cuda backend, is it right?
--Junchao Zhang
On Mon, Nov 14, 2022 at 12:13 PM Fackler, Philip via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
This is an issue I've brought up before (and discussed in-person with Richard). I wanted to bring it up again because I'm hitting the limits of what I know to do, and I need help figuring this out.
The problem can be reproduced using Xolotl's "develop" branch built against a petsc build with kokkos and kokkos-kernels enabled. Then, either add the relevant kokkos options to the "petscArgs=" line in the system test parameter file(s), or just replace the system test parameter files with the ones from the "feature-petsc-kokkos" branch. See here the files that begin with "params_system_".
Note that those files use the "kokkos" options, but the problem is similar using the corresponding cuda/cusparse options. I've already tried building kokkos-kernels with no TPLs and got slightly different results, but the same problem.
Any help would be appreciated.
Philip Fackler
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230327/b60454e5/attachment-0001.html>
