[petsc-users] Memory Usage in Matrix Assembly.
Matthew Knepley
knepley at gmail.com
Tue Mar 14 15:55:14 CDT 2023
On Tue, Mar 14, 2023 at 12:01 PM Dave May <dave.mayhem23 at gmail.com> wrote:
> On Tue, 14 Mar 2023 at 07:59, Pantelis Moschopoulos <
> pmoschopoulos at outlook.com> wrote:
>> Dear Dave,
>> Yes, I observe this in parallel runs. How I can change the parallel
>> layout of the matrix? In my implementation, I read the mesh file, and the I
>> split the domain where the first rank gets the first N elements, the second
>> rank gets the next N elements etc. Should I use metis to distribute
>> elements?
>> Note that I use continuous finite elements, which means that some values
>> will be cached in a temporary buffer.
> Sure. With CG FE you will always have some DOFs which need to be cached,
> however the number of cached values will be minimized if you follow Barry's
> advice. If you do what Barry suggests, only the DOFs which live on the
> boundary of your element-wise defined sub-domains would need to cached.
Note that we have direct support for unstructured meshes (Plex) with
partitioning and redistribution, rather than translating them to purely
algebraic language.
Matt
> Thanks,
> Dave
>> Thank you very much,
>> Pantelis
>> *From:* Dave May <dave.mayhem23 at gmail.com>
>> *Sent:* Tuesday, March 14, 2023 4:40 PM
>> *To:* Pantelis Moschopoulos <pmoschopoulos at outlook.com>
>> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>> *Subject:* Re: [petsc-users] Memory Usage in Matrix Assembly.
>> On Tue 14. Mar 2023 at 07:15, Pantelis Moschopoulos <
>> Hi everyone,
>> I am a new Petsc user that incorporates Petsc for FEM in a Fortran code.
>> My question concerns the sudden increase of the memory that Petsc needs
>> during the assembly of the jacobian matrix. After this point, memory is
>> freed. It seems to me like Petsc performs memory allocations and the
>> deallocations during assembly.
>> I have used the following commands with no success:
>> CALL MatSetOption(petsc_A, MAT_NEW_NONZERO_LOCATIONS,PETSC_FALSE,ier)
>> CALL MatSetOption(petsc_A, MAT_NEW_NONZERO_LOCATION_ERR,PETSC_TRUE,ier)
>> CALL MatSetOption(petsc_A, MAT_NEW_NONZERO_ALLOCATION_ERR,
>> PETSC_TRUE,ier).
>> CALL MatSetOption(petsc_A, MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE,ier)
>> The structure of the matrix does not change during my simulation, just
>> the values. I am expecting this behavior the first time that I create this
>> matrix because the preallocation instructions that I use are not very
>> accurate but this continues every time I assemble the matrix.
>> What I am missing here?
>> I am guessing this observation is seen when you run a parallel job.
>> MatSetValues() will cache values in a temporary memory buffer if the
>> values are to be sent to a different MPI rank.
>> Hence if the parallel layout of your matrix doesn’t closely match the
>> layout of the DOFs on each mesh sub-domain, then a huge number of values
>> can potentially be cached. After you call MatAssemblyBegin(),
>> MatAssemblyEnd() this cache will be freed.
>> Thanks,
>> Dave
>> Pantelis
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230314/c9110c77/attachment-0001.html>
