[petsc-users] Using PETSc GPU backend
Ng, Cho-Kuen
cho at slac.stanford.edu
Thu Jun 29 22:32:14 CDT 2023
Mark,
Thanks for the information. How do I put the runtime options for the executable, say, a.out, which does not have the provision to append arguments? Do I need to change the C++ main to read in the options?
Cho
Sent: Thursday, June 29, 2023 5:55 PM
To: Ng, Cho-Kuen <cho at slac.stanford.edu>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Using PETSc GPU backend
Run with options: -mat_type aijcusparse -vec_type cuda -log_view -options_left
The last column of the performance data (from -log_view) will be the percent flops on the GPU. Check that that is > 0.
The end of the output will list the options that were used and options that were _not_ used (if any). Check that there are no options left.
On Thu, Jun 29, 2023 at 7:50 PM Ng, Cho-Kuen via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I installed PETSc on Perlmutter using "spack install petsc+cuda+zoltan" and used it by "spack load petsc/fwge6pf". Then I compiled the application code (purely CPU code) linking to the petsc package, hoping that I can get performance improvement using the petsc GPU backend. However, the timing was the same using the same number of MPI tasks with and without GPU accelerators. Have I missed something in the process, for example, setting up PETSc options at runtime to use the GPU backend?
Cho
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230630/2bcedfed/attachment.html>
