[petsc-users] SOLVE + PC combination for 7 point stencil (unstructured) poisson solution
Tue Jun 27 13:08:06 CDT 2023
On Tue, Jun 27, 2023 at 11:23 AM Vanella, Marcos (Fed) <
marcos.vanella at nist.gov> wrote:
> Hi Mark and Matt, I tried swapping the preconditioner to cholmod and also
> the hypre Boomer AMG. They work just fine for my case. I also got my hands
> on a machine with NVIDIA gpus in one of our AI clusters. I compiled PETSc
> to make use of cuda and cuda-enabled openmpi (with gcc).
> I'm running the previous tests and want to also check some of the cuda
> enabled solvers. I was able to submit a case for the default Krylov solver
> with these runtime flags: -vec_type seqcuda -mat_type seqaijcusparse
> -pc_type cholesky -pc_factor_mat_solver_type cusparse. The case run to
> completion.
> I guess my question now is how do I monitor (if there is a way) that the
> GPU is being used in the calculation, and any other stats?
You should get that automatically with
  -log_view
If you want finer-grained profiling of the kernels, you can use
  -log_view_gpu_time
but it can slows things down.
> Also, which other solver combination using GPU would you recommend for me
> to try? Can we compile PETSc with the cuda enabled version for CHOLMOD and
> HYPRE?
Hypre has GPU support but not CHOLMOD. There are no rules of thumb right
now for GPUs. It depends on what card you have, what version of the driver,
what version of the libraries, etc. It is very fragile. Hopefully this
period ends soon, but I am not optimistic. Unless you are very confident
that GPUs will help,
I would not recommend spending the time.
     Matt
> Thank you for your help!
> Marcos
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Monday, June 26, 2023 12:11 PM
> *To:* Vanella, Marcos (Fed) <marcos.vanella at nist.gov>
> *Cc:* Mark Adams <mfadams at lbl.gov>; petsc-users at mcs.anl.gov <
> petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] SOLVE + PC combination for 7 point stencil
> On Mon, Jun 26, 2023 at 12:08 PM Vanella, Marcos (Fed) via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Than you Matt and Mark, I'll try your suggestions. To configure with hypre
> can I just use the --download-hypre configure line?
> Yes,
>   Thanks,
>     Matt
> That is what I did with suitesparse, very nice.
> *From:* Mark Adams <mfadams at lbl.gov>
> *Sent:* Monday, June 26, 2023 12:05 PM
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> I'm not sure what MG is doing with an "unstructured" problem. I assume you
> are not using DMDA.
> -pc_type gamg should work
> I would configure with hypre and try that also: -pc_type hypre
> As Matt said MG should be faster. How many iterations was it taking?
> Try a 100^3 and check that the iteration count does not change much, if at
> all.
> Mark
> On Mon, Jun 26, 2023 at 11:35 AM Vanella, Marcos (Fed) via petsc-users <
> Hi, I was wondering if anyone has experience on what combinations are more
> efficient to solve a Poisson problem derived from a 7 point stencil on a
> single mesh (serial).
> I've been doing some tests of multigrid and cholesky on a 50^3 mesh. *-pc_type
> mg* takes about 75% more time than *-pc_type cholesky
> -pc_factor_mat_solver_type cholmod* for the case I'm testing.
> I'm new to PETSc so any suggestions are most welcome and appreciated,
> Marcos
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230627/0513ca4e/attachment-0001.html>
