[petsc-users] Inquiry about the c++ destructor and PetscFinalize.
neil liu
liufield at gmail.com
Wed Jun 21 15:58:14 CDT 2023
It works well for one processor; but when I tried two processors using
mpiexec -n 2 ./ex1,
there is an error shown as belows. If the line "DMDestroy(dmDist)" is
commented out, the error will go away. This is a little confusing for me.
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Corrupt argument: https://petsc.org/release/faq/#valgrind
[1]PETSC ERROR: Object already free: Parameter # 1
[1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.19.1, Apr 30, 2023
[1]PETSC ERROR: ./ex1 on a arch-linux-c-debug named kirin.remcominc.com by
xiaodong.liu Wed Jun 21 16:54:46 2023
[1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran --download-mpich --download-fblaslapack
--download-ctetgen
[1]PETSC ERROR: #1 DMDestroy() at
/home/xiaodong.liu/Documents/petsc-3.19.1/src/dm/interface/dm.c:639
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Corrupt argument: https://petsc.org/release/faq/#valgrind
[0]PETSC ERROR: Object already free: Parameter # 1
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.19.1, Apr 30, 2023
[0]PETSC ERROR: ./ex1 on a arch-linux-c-debug named kirin.remcominc.com by
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--download-ctetgen
[0]PETSC ERROR: #1 DMDestroy() at
On Tue, Jun 20, 2023 at 12:36 PM neil liu <liufield at gmail.com> wrote:
> Thanks a lot, Constantine. It works pretty well.
> On Fri, Jun 16, 2023 at 6:52 PM Constantine Khrulev <ckhroulev at alaska.edu>
> wrote:
>> In your code the destructor of DMManage is called at the end of scope,
>> i.e. after the PetscFinalize() call.
>> You should be able to avoid this error by putting "DMManage objDMManage"
>> in a code block to limit its scope and ensure that it is destroyed
>> before PETSc is finalized:
>> int main(int argc, char** argv) {
>> PetscFunctionBeginUser;
>> PetscCall(PetscInitialize(&argc, &argv, NULL, help));
>> DMManage objDMManage;
>> } // objDMManage is destroyed here
>> PetscFinalize();
>> return 0;
>> On 6/16/23 14:13, neil liu wrote:
>> > Dear Petsc developers,
>> > I am trying to use Petsc with C++. And came across one issue.
>> > Class DMManage has been defined, one default constructor and
>> > destructor has been defined there.
>> > The code has a runtime error, "double free or corruption". Finally I
>> > found that, this is due to PetscFinalize. If I called explicitly the
>> > destructor before this PetscFinalze, the error will disappear.
>> > Does that mean PetscFinalize do some work to destroy DM?
>> > Thanks,
>> > #include <petscdmplex.h>
>> > #include <petscdmadaptor.h>
>> > #include <petscds.h>
>> > #include <petscviewerhdf5.h>
>> > class DMManage{
>> > PetscSF distributionSF;
>> > public:
>> > DM dm;
>> > DMManage();
>> > ~DMManage();
>> > DMManage::DMManage(){
>> > const char filename[] = "ParallelWaveguide.msh";
>> > DM dmDist;
>> > PetscViewer viewer;
>> > PetscViewerCreate(PETSC_COMM_WORLD, &viewer);
>> > PetscViewerSetType(viewer, PETSCVIEWERASCII);
>> > PetscViewerFileSetMode(viewer, FILE_MODE_READ);
>> > PetscViewerFileSetName(viewer, filename);
>> > DMPlexCreateGmsh(PETSC_COMM_WORLD, viewer, PETSC_TRUE, &dm);
>> > PetscViewerDestroy(&viewer);
>> > PetscInt overlap = 0;
>> > DMPlexDistribute(dm, overlap, &distributionSF, &dmDist);
>> > std::cout<<&dm<<std::endl;
>> > if (dmDist) {
>> > DMDestroy(&dm);
>> > dm = dmDist;
>> > DMDestroy(&dmDist);
>> > DMManage::~DMManage(){
>> > DMDestroy(&dm);
>> > PetscFinalize();
>> > return 0;
>> Constantine
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230621/af19e4c7/attachment.html>
