[petsc-users] Inquiry about the c++ destructor and PetscFinalize.
neil liu
liufield at gmail.com
Tue Jun 20 11:36:20 CDT 2023
Thanks a lot, Constantine. It works pretty well.
On Fri, Jun 16, 2023 at 6:52 PM Constantine Khrulev <ckhroulev at alaska.edu>
wrote:
> In your code the destructor of DMManage is called at the end of scope,
> i.e. after the PetscFinalize() call.
> You should be able to avoid this error by putting "DMManage objDMManage"
> in a code block to limit its scope and ensure that it is destroyed
> before PETSc is finalized:
> int main(int argc, char** argv) {
> PetscFunctionBeginUser;
> PetscCall(PetscInitialize(&argc, &argv, NULL, help));
> DMManage objDMManage;
> } // objDMManage is destroyed here
> PetscFinalize();
> return 0;
> On 6/16/23 14:13, neil liu wrote:
> > Dear Petsc developers,
> > I am trying to use Petsc with C++. And came across one issue.
> > Class DMManage has been defined, one default constructor and
> > destructor has been defined there.
> > The code has a runtime error, "double free or corruption". Finally I
> > found that, this is due to PetscFinalize. If I called explicitly the
> > destructor before this PetscFinalze, the error will disappear.
> > Does that mean PetscFinalize do some work to destroy DM?
> > Thanks,
> > #include <petscdmplex.h>
> > #include <petscdmadaptor.h>
> > #include <petscds.h>
> > #include <petscviewerhdf5.h>
> > class DMManage{
> > PetscSF distributionSF;
> > public:
> > DM dm;
> > DMManage();
> > ~DMManage();
> > DMManage::DMManage(){
> > const char filename[] = "ParallelWaveguide.msh";
> > DM dmDist;
> > PetscViewer viewer;
> > PetscViewerCreate(PETSC_COMM_WORLD, &viewer);
> > PetscViewerSetType(viewer, PETSCVIEWERASCII);
> > PetscViewerFileSetMode(viewer, FILE_MODE_READ);
> > PetscViewerFileSetName(viewer, filename);
> > DMPlexCreateGmsh(PETSC_COMM_WORLD, viewer, PETSC_TRUE, &dm);
> > PetscViewerDestroy(&viewer);
> > PetscInt overlap = 0;
> > DMPlexDistribute(dm, overlap, &distributionSF, &dmDist);
> > std::cout<<&dm<<std::endl;
> > if (dmDist) {
> > DMDestroy(&dm);
> > dm = dmDist;
> > DMDestroy(&dmDist);
> > DMManage::~DMManage(){
> > DMDestroy(&dm);
> > PetscFinalize();
> > return 0;
> Constantine
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230620/9ba6e26a/attachment.html>
