[petsc-users] IS natural numbering to global numbering
YuSh Lo ysjosh.lo at gmail.com
Sun Jun 18 13:21:46 CDT 2023
Hi Matthew,
Yes, I have called DMPlexDistribute().
so what I do is:
CALL DMSetUseNatural(serialDM, PETSC_TRUE, errorCode)
CALL DMPlexDistribute(serialDM, 0, migrationSF, distributedDM, errorCode)
CALL DMPlexGetGlobalToNaturalSF(serialDM, naturalSF, errorCode)
CALL PetscSFView(naturalSF, PETSC_VIEWER_STDOUT_WORLD, errorCode)
The naturalSF is null.
Josh
Matthew Knepley <knepley at gmail.com> 於 2023年6月18日 週日 上午7:42寫道:
> On Sun, Jun 18, 2023 at 2:12 AM YuSh Lo <ysjosh.lo at gmail.com> wrote:
>> I am getting a null PetscSF after calling DMPlexGetGlobalToNatural
> Did you call DMDIstribute()? This is where the map is created because
> until then, the map is identity.
>   Thanks,
>      Matt
>> YuSh Lo <ysjosh.lo at gmail.com> 於 2023年6月18日 週日 上午12:18寫道:
>>> Hi Matthew,
>>> After setting DMSetUseNatural to true and calling
>>> DMPlexGetGlobalToNatural,
>>> I call PestcSFView right away, it gives segmentation fault.
>>> I have also tried DMGetNaturalSF, it also gives segmentation fault when
>>> calling PetscSFView.
>>> I use PETSC_VIEWER_STDOUT_WORLD as PetscViewer
>>> Thanks,
>>> Josh
>>> Matthew Knepley <knepley at gmail.com> 於 2023年6月9日 週五 下午1:04寫道:
>>>> On Fri, Jun 9, 2023 at 1:46 PM YuSh Lo <ysjosh.lo at gmail.com> wrote:
>>>>> Hi Barry,
>>>>> Is there any way to use the mapping generated by DMPlexDistribute
>>>>> along with AO?
>>>> For Plex, if you turn on
>>>>   https://petsc.org/main/manualpages/DM/DMSetUseNatural/
>>>> before DMPlexDistribute(), it will compute and store a GlobalToNatural
>>>> map. This can be
>>>> used to map vectors back and forth, but you can extract the SF
>>>> <https://petsc.org/main/manualpages/DMPlex/DMPlexGetGlobalToNaturalSF/>
>>>> and use that to remap your IS, by extracting the indices.
>>>>   THanks,
>>>>      Matt
>>>>> Thanks,
>>>>> Josh
>>>>> Barry Smith <bsmith at petsc.dev> 於 2023年6月9日 週五 上午10:42寫道:
>>>>>>   You might be looking for
>>>>>> https://petsc.org/release/manualpages/AO/AO/#ao
>>>>>> On Jun 9, 2023, at 11:02 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> An IS is just an array of integers. We need your context.
>>>>>> Is this question for sparse matrices? If so look at the documentation
>>>>>> on the AIJ matrix construction and the global vertex numbering system.
>>>>>> Mark
>>>>>> On Thu, Jun 8, 2023 at 1:15 PM YuSh Lo <ysjosh.lo at gmail.com> wrote:
>>>>>>> Hi,
>>>>>>> I have an IS that contains some vertex that is in natural numbering.
>>>>>>> How do I map them to global numbering without being distributed?
>>>>>>> Thanks,
>>>>>>> Josh
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230618/3e428f80/attachment.html>
