[petsc-users] IS natural numbering to global numbering
Matthew Knepley
knepley at gmail.com
Sun Jun 18 07:42:23 CDT 2023
On Sun, Jun 18, 2023 at 2:12 AM YuSh Lo <ysjosh.lo at gmail.com> wrote:
> I am getting a null PetscSF after calling DMPlexGetGlobalToNatural
Did you call DMDIstribute()? This is where the map is created because until
then, the map is identity.
Matt
> YuSh Lo <ysjosh.lo at gmail.com> 於 2023年6月18日 週日 上午12:18寫道:
>> Hi Matthew,
>> After setting DMSetUseNatural to true and calling
>> DMPlexGetGlobalToNatural,
>> I call PestcSFView right away, it gives segmentation fault.
>> I have also tried DMGetNaturalSF, it also gives segmentation fault when
>> calling PetscSFView.
>> I use PETSC_VIEWER_STDOUT_WORLD as PetscViewer
>> Thanks,
>> Josh
>> Matthew Knepley <knepley at gmail.com> 於 2023年6月9日 週五 下午1:04寫道:
>>> On Fri, Jun 9, 2023 at 1:46 PM YuSh Lo <ysjosh.lo at gmail.com> wrote:
>>>> Hi Barry,
>>>> Is there any way to use the mapping generated by DMPlexDistribute along
>>>> with AO?
>>> For Plex, if you turn on
>>> https://petsc.org/main/manualpages/DM/DMSetUseNatural/
>>> before DMPlexDistribute(), it will compute and store a GlobalToNatural
>>> map. This can be
>>> used to map vectors back and forth, but you can extract the SF
>>> DMPlexGetGlobalToNaturalSF
>>> <https://petsc.org/main/manualpages/DMPlex/DMPlexGetGlobalToNaturalSF/>
>>> and use that to remap your IS, by extracting the indices.
>>> THanks,
>>> Matt
>>>> Thanks,
>>>> Josh
>>>> Barry Smith <bsmith at petsc.dev> 於 2023年6月9日 週五 上午10:42寫道:
>>>>> You might be looking for
>>>>> https://petsc.org/release/manualpages/AO/AO/#ao
>>>>> On Jun 9, 2023, at 11:02 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> An IS is just an array of integers. We need your context.
>>>>> Is this question for sparse matrices? If so look at the documentation
>>>>> on the AIJ matrix construction and the global vertex numbering system.
>>>>> Mark
>>>>> On Thu, Jun 8, 2023 at 1:15 PM YuSh Lo <ysjosh.lo at gmail.com> wrote:
>>>>>> Hi,
>>>>>> I have an IS that contains some vertex that is in natural numbering.
>>>>>> How do I map them to global numbering without being distributed?
>>>>>> Thanks,
>>>>>> Josh
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230618/894f15dc/attachment.html>
