[petsc-users] Interpolation Between DMSTAG Objects
Colton Bryant
coltonbryant2021 at u.northwestern.edu
Wed Jun 14 15:03:50 CDT 2023
Hi Matt,
Thanks for the reply! I haven't played with DMSwarm yet but that looks like
it would be a very nice solution to this sort of thing. I ended up using
VecScatter to transfer the donor grid values to the destination process
then doing the interpolation there. Not the most elegant solution but it's
definitely not the bottleneck in my code right now!
Thanks again,
Colton
On Wed, Jun 14, 2023 at 2:17 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jun 7, 2023 at 10:46 AM Colton Bryant <
> coltonbryant2021 at u.northwestern.edu> wrote:
>> Hello,
>> I am new to PETSc so apologies in advance if there is an easy answer to
>> this question I've overlooked.
>> I have a problem in which the computational domain is divided into two
>> overlapping regions (overset grids). I would like to discretize each region
>> as a separate DMSTAG object. What I do not understand is how to go about
>> interpolating a vector from say DM1 onto nodes in DM2. My current (likely
>> inefficient) idea is to create vectors of query points on DM2, share these
>> vectors among all processes, perform the interpolations on DM1, and then
>> insert the results into the vector on DM2.
>> Before I embark on manually setting up the communication here I wanted to
>> just ask if there is any native support for this kind of operation in PETSc
>> I may be missing.
>> Thanks in advance for any advice!
> This sounds like a good first step. We do not currently have support for
> this, but I would like to support this pattern. I was thinking
> 1) Create a DMSwarm() with your query points
> 2) Call DMSwarmMigrate() to put the points on the correct processors
> This needs some implementation work, but is not super hard. We need
> to preserve the map so
> that you can send the results back.
> 3) Interpolate on the DMStag
> 3) Use the PetscSF that migrated particles to send back the results
> Joe and I are working on this support.
> Thanks,
> Matt
>> Best,
>> Colton Bryant
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230614/e6b2eed5/attachment.html>
