[petsc-users] win32fe?
Satish Balay
balay at mcs.anl.gov
Tue Jan 31 11:32:13 CST 2023
Assuming 'icx/ifx' compiler options are same as 'icl/ifort' - you can try:
--with-cc='win32fe icl --use icx' --with-cxx='win32fe icl --use icx' --with-fc='win32e ifort --use ifx'
Also check 'win32fe --help'
However I think the above assumption [i.e icx is a drop in replacement for icl] is likely invalid - so this might not work.
Note: petsc/main has shell wrappers for 'win32fe icl' - so one could add similar wrappers for icx - if the above would work.
balay at p1 /home/balay/petsc (main =)
$ cat lib/petsc/bin/win32fe/win_cl
#!/usr/bin/env sh
# Wrapper for Microsoft Windows cl using win32fe as a full path compiler
p=`dirname $0`
${p}/win32fe cl $*
The sources for win32fe are at https://bitbucket.org/petsc/win32fe
And 'win32fe icl --verbose' is useful to understand the commands its invoking internally.
Satish
On Tue, 31 Jan 2023, Daniel Stone wrote:
> Hello all,
> I am currently having to figure out a way to get petsc working on windows,
> using compilers from the intel oneAPI package. This means new compiler
> names, such as "icx" for the c compiler and "ifx" for the fortran one.
> I see from the installation instructions, and from old notes from a
> collegue, how to set up the cygwin environment and to use, e.g.,
> --with-cc="win32fe icl" (if using an older intel compiler) when configuring.
> Unfortunately,win32fe only workes with a number of fixed (older) compilers,
> and simply cannot be made to work with icx or ifx, as far as I can see.
> When I try to not use the compilers without win32fe (e.g. --withcc=icx"),
> I get a slew of problems when the configure script trys to compile and link
> test c programs. It seems that icx works fine, but gets extemely confused
> when having to target output files to, e.g., /tmp or /anywhere/non/trivial,
> when running under cygwin. Is this the sort of problem that win32fe is
> intended to solve?
> I can't find any source code for win32fe, nor really any explainations of
> what it's supposed to be doing or how it works. Since it looks like I have
> to find a way of making it work with icx and ifx, I'm a bit stuck. Can
> anyone
> provide any insight as to what/how win32 does, or where I can look for some?
> Many thanks,
> Daniel
