[petsc-users] Question about error
Tue Jan 31 06:58:02 CST 2023
On Tue, Jan 31, 2023 at 5:49 AM 김성익 <ksi2443 at gmail.com> wrote:
> Hello,
> There are different results from different commands.
> However, it should be computed same result between different commands.
> The first command is just as below
> './app' (app is my petsc application)
> and the results are as below.
> [image: image.png]
> And the second command is just as below
> 'mpiexec -n 1 ./app'
> and I got the result what I want.
> Actually first of all, I suspected my a1.c:195. However there is no error.
> How can I fix this problem??
> I don't know where to start.
> We continue to investigate from the input data to the structure, but we
> are unable to find any suspicious parts.
What MPI are you using? It is possible that it requires you to run with
mpiexec. To track down the error, you
can run with -start_in_debugger, and when you get the signal, print out the
stack.
     Matt
> Thanks,
> Hyung Kim
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230131/7354fcf3/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230131/7354fcf3/attachment-0001.png>
