[petsc-users] multi GPU partitions have very different memory usage
Mark Adams
mfadams at lbl.gov
Thu Jan 19 08:40:37 CST 2023
On Wed, Jan 18, 2023 at 6:03 PM Mark Lohry <mlohry at gmail.com> wrote:
> Thanks Mark, I'll try the kokkos bit. Any other suggestions for minimizing
> memory besides the obvious use less levels?
> Unfortunately Jacobi does poorly compared to ILU on these systems.
> I'm seeing grid complexity 1.48 and operator complexity 1.75 with
> pc_gamg_square_graph 0, and 1.15/1.25 with it at 1.
That looks good. Use 1.
> Additionally the convergence rate is pretty healthy with 5 gmres+asm
> smooths but very bad with 5 Richardson+asm.
Yea, it needs to be damped and GMRES does that automatically.
> On Wed, Jan 18, 2023, 4:48 PM Mark Adams <mfadams at lbl.gov> wrote:
>> cusparse matrix triple product takes a lot of memory. We usually use
>> Kokkos, configured with TPL turned off.
>> If you have a complex problem different parts of the domain can coarsen
>> at different rates.
>> Jacobi instead of asm will save a fair amount od memory.
>> If you run with -ksp_view you will see operator/matrix complexity from
>> GAMG. These should be < 1.5,
>> Mark
>> On Wed, Jan 18, 2023 at 3:42 PM Mark Lohry <mlohry at gmail.com> wrote:
>>> With asm I see a range of 8GB-13GB, slightly smaller ratio but that
>>> probably explains it (does this still seem like a lot of memory to you for
>>> the problem size?)
>>> In general I don't have the same number of blocks per row, so I suppose
>>> it makes sense there's some memory imbalance.
>>> On Wed, Jan 18, 2023 at 3:35 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>> Can your problem have load imbalance?
>>>> You might try '-pc_type asm' (and/or jacobi) to see your baseline load
>>>> imbalance.
>>>> GAMG can add some load imbalance but start by getting a baseline.
>>>> Mark
>>>> On Wed, Jan 18, 2023 at 2:54 PM Mark Lohry <mlohry at gmail.com> wrote:
>>>>> Q0) does -memory_view trace GPU memory as well, or is there another
>>>>> method to query the peak device memory allocation?
>>>>> Q1) I'm loading a aijcusparse matrix with MatLoad, and running with
>>>>> -ksp_type fgmres -pc_type gamg -mg_levels_pc_type asm with mat info
>>>>> 27,142,948 rows and cols, bs=4, total nonzeros 759,709,392. Using 8 ranks
>>>>> on 8x80GB GPUs, and during the setup phase before crashing with
>>>>> CUSPARSE_STATUS_INSUFFICIENT_RESOURCES nvidia-smi shows the below pasted
>>>>> content.
>>>>> GPU memory usage spanning from 36GB-50GB but with one rank at 77GB. Is
>>>>> this expected? Do I need to manually repartition this somehow?
>>>>> Thanks,
>>>>> Mark
>>>>> | Processes:
>>>>> | GPU GI CI PID Type Process name GPU
>>>>> Memory |
>>>>> | ID ID
>>>>> Usage |
>>>>> | 0 N/A N/A 1630309 C
>>>>> nvidia-cuda-mps-server 27MiB |
>>>>> | 0 N/A N/A 1696543 C ./petsc_solver_test
>>>>> 38407MiB |
>>>>> | 0 N/A N/A 1696544 C ./petsc_solver_test
>>>>> 467MiB |
>>>>> | 0 N/A N/A 1696545 C ./petsc_solver_test
>>>>> 467MiB |
>>>>> | 0 N/A N/A 1696546 C ./petsc_solver_test
>>>>> 467MiB |
>>>>> | 0 N/A N/A 1696548 C ./petsc_solver_test
>>>>> 467MiB |
>>>>> | 0 N/A N/A 1696550 C ./petsc_solver_test
>>>>> 471MiB |
>>>>> | 0 N/A N/A 1696551 C ./petsc_solver_test
>>>>> 467MiB |
>>>>> | 0 N/A N/A 1696552 C ./petsc_solver_test
>>>>> 467MiB |
>>>>> | 1 N/A N/A 1630309 C
>>>>> | 1 N/A N/A 1696544 C ./petsc_solver_test
>>>>> 35849MiB |
>>>>> | 2 N/A N/A 1630309 C
>>>>> | 2 N/A N/A 1696545 C ./petsc_solver_test
>>>>> 36719MiB |
>>>>> | 3 N/A N/A 1630309 C
>>>>> | 3 N/A N/A 1696546 C ./petsc_solver_test
>>>>> 37343MiB |
>>>>> | 4 N/A N/A 1630309 C
>>>>> | 4 N/A N/A 1696548 C ./petsc_solver_test
>>>>> 36935MiB |
>>>>> | 5 N/A N/A 1630309 C
>>>>> | 5 N/A N/A 1696550 C ./petsc_solver_test
>>>>> 49953MiB |
>>>>> | 6 N/A N/A 1630309 C
>>>>> | 6 N/A N/A 1696551 C ./petsc_solver_test
>>>>> 47693MiB |
>>>>> | 7 N/A N/A 1630309 C
>>>>> | 7 N/A N/A 1696552 C ./petsc_solver_test
>>>>> 77331MiB |
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230119/52d38ad1/attachment.html>
