[petsc-users] coordinate degrees of freedom for 2nd-order gmsh mesh
Matthew Knepley
knepley at gmail.com
Thu Jan 12 20:14:34 CST 2023
On Thu, Jan 12, 2023 at 4:10 PM Dave May <dave.mayhem23 at gmail.com> wrote:
> On Thu 12. Jan 2023 at 17:58, Blaise Bourdin <bourdin at mcmaster.ca> wrote:
>> Out of curiosity, what is the rationale for _reading_ high order gmsh
>> meshes?
> GMSH can use a CAD engine like OpenCascade. This provides geometric
> representations via things like BSplines. Such geometric representation are
> not exposed to the users application code, nor are they embedded in any
> mesh format GMSH emits. The next best thing is to use a high order
> representation of the mesh geometry and project the CAD geometry (say a
> BSpline) into this higher order function space. The projection of the
> geometry is a quantity that can be described with the .msh format.
Note that PETSc can directly read CAD files now and mesh over them.
> Is it so that one can write data back in native gmsh format?
> No.
> Cheers,
> Dave
>> Regards,
>> Blaise
>> On Jan 12, 2023, at 7:13 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jan 12, 2023 at 1:33 PM Jed Brown <jed at jedbrown.org> wrote:
>>> It's confusing, but this line makes high order simplices always read as
>>> discontinuous coordinate spaces. I would love if someone would revisit
>>> that, perhaps also using DMPlexSetIsoperiodicFaceSF(),
>> Perhaps as a switch, but there is no way I am getting rid of the current
>> periodicity. As we have discussed before, breaking the topological relation
>> is a non-starter for me.
>> It does look like higher order Gmsh does read as DG. We can just project
>> that to CG for non-periodic stuff.
>> Thanks,
>> Matt
>> which should simplify the code and avoid the confusing cell coordinates
>>> pattern. Sadly, I don't have time to dive in.
>>> https://gitlab.com/petsc/petsc/-/commit/066ea43f7f75752f012be6cd06b6107ebe84cc6d#3616cad8148970af5b97293c49492ff893e25b59_1552_1724
>>> "Daniel R. Shapero" <shapero at uw.edu> writes:
>>> > Sorry either your mail system or mine prevented me from attaching the
>>> file,
>>> > so I put it on pastebin:
>>> > https://pastebin.com/awFpc1Js
>>> > On Wed, Jan 11, 2023 at 4:54 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> >> Can you send the .msh file? I still have not installed Gmsh :)
>>> >> Thanks,
>>> >> Matt
>>> >> On Wed, Jan 11, 2023 at 2:43 PM Daniel R. Shapero <shapero at uw.edu>
>>> wrote:
>>> >>> Hi all -- I'm trying to read in 2nd-order / piecewise quadratic
>>> meshes
>>> >>> that are generated by gmsh and I don't understand how the
>>> coordinates are
>>> >>> stored in the plex. I've been discussing this with Matt Knepley here
>>> https://urldefense.com/v3/__https://github.com/firedrakeproject/firedrake/issues/982__;!!K-Hz7m0Vt54!hL9WLR51ieyHFZx8N9AjhDwJCRpvmQto9CL1XOTkkAxFfUbtsabHuBDOATnWyP6lQszhA2gOStva7A$
>>> >>> as it pertains to Firedrake but I think this is more an issue at the
>>> PETSc
>>> >>> level.
>>> >>> This code
>>> https://urldefense.com/v3/__https://gist.github.com/danshapero/a140daaf951ba58c48285ec29f5973cc__;!!K-Hz7m0Vt54!hL9WLR51ieyHFZx8N9AjhDwJCRpvmQto9CL1XOTkkAxFfUbtsabHuBDOATnWyP6lQszhA2hho2eD1g$
>>> >>> uses gmsh to generate a 2nd-order mesh of the unit disk, read it
>>> into a
>>> >>> DMPlex, print out the number of cells in each depth stratum, and
>>> finally
>>> >>> print a view of the coordinate DM's section. The resulting mesh has
>>> 64
>>> >>> triangles, 104 edges, and 41 vertices. For 2nd-order meshes, I'd
>>> expected
>>> >>> there to be 2 degrees of freedom at each node and 2 at each edge. The
>>> >>> output is:
>>> >>> Depth strata: [(64, 105), (105, 209), (0, 64)]
>>> >>> PetscSection Object: 1 MPI process
>>> >>> type not yet set
>>> >>> 1 fields
>>> >>> field 0 with 2 components
>>> >>> Process 0:
>>> >>> ( 0) dim 12 offset 0
>>> >>> ( 1) dim 12 offset 12
>>> >>> ( 2) dim 12 offset 24
>>> >>> ( 62) dim 12 offset 744
>>> >>> ( 63) dim 12 offset 756
>>> >>> ( 64) dim 0 offset 768
>>> >>> ( 65) dim 0 offset 768
>>> >>> ( 207) dim 0 offset 768
>>> >>> ( 208) dim 0 offset 768
>>> >>> PetscSectionSym Object: 1 MPI process
>>> >>> type: label
>>> >>> Label 'depth'
>>> >>> Symmetry for stratum value 0 (0 dofs per point): no symmetries
>>> >>> Symmetry for stratum value 1 (0 dofs per point): no symmetries
>>> >>> Symmetry for stratum value 2 (12 dofs per point):
>>> >>> Orientation range: [-3, 3)
>>> >>> Symmetry for stratum value -1 (0 dofs per point): no symmetries
>>> >>> The output suggests that there are 12 degrees of freedom in each
>>> >>> triangle. That would mean the coordinate field is discontinuous
>>> across cell
>>> >>> boundaries. Can someone explain what's going on? I tried reading the
>>> .msh
>>> >>> file but it's totally inscrutable to me. I'm happy to RTFSC if
>>> someone
>>> >>> points me in the right direction. Matt tells me that the coordinate
>>> field
>>> >>> should only be discontinuous if the mesh is periodic, but this mesh
>>> >>> shouldn't be periodic.
>>> >> What most experimenters take for granted before they begin their
>>> >> experiments is infinitely more interesting than any results to which
>>> their
>>> >> experiments lead.
>>> >> -- Norbert Wiener
>>> >> https://www.cse.buffalo.edu/~knepley/
>>> https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!K-Hz7m0Vt54!hL9WLR51ieyHFZx8N9AjhDwJCRpvmQto9CL1XOTkkAxFfUbtsabHuBDOATnWyP6lQszhA2go23tjRg$
>> experiments lead.
>> -- Norbert Wiener
>> <http://www.cse.buffalo.edu/~knepley/>
>> Canada Research Chair in Mathematical and Computational Aspects of Solid
>> Mechanics (Tier 1)
>> Professor, Department of Mathematics & Statistics
>> Hamilton Hall room 409A, McMaster University
>> 1280 Main Street West, Hamilton,
>> <https://www.google.com/maps/search/1280+Main+Street+West,+Hamilton,+Ontario+L8S+4K1,+Canada?entry=gmail&source=g>
>> Ontario L8S 4K1, Canada
>> https://www.math.mcmaster.ca/bourdin | +1 (905) 525 9140 ext. 27243
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230112/5df44825/attachment.html>
