[petsc-users] PETSC install
Barry Smith
bsmith at petsc.dev
Wed Jan 11 07:22:09 CST 2023
https://petsc.org/release/faq/#what-does-the-message-hwloc-linux-ignoring-pci-device-with-non-16bit-domain-mean
> On Jan 11, 2023, at 5:03 AM, Sijie Zhang <zhan2355 at purdue.edu> wrote:
> Hi,
> When I try to install petsc on my workstation, I got the following error. Can you help me with that?
> Thank you and best regards.
> Sijie
> Running check examples to verify correct installation
> Using PETSC_DIR=/home/zhangsijie1995/Documents/Package/petsc-3.18.3 and PETSC_ARCH=arch-linux-c-debug
> Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
> See https://petsc.org/release/faq/
> hwloc/linux: Ignoring PCI device with non-16bit domain.
> Pass --enable-32bits-pci-domain to configure to support such devices
> (warning: it would break the library ABI, don't enable unless really needed).
> lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
> Number of SNES iterations = 2
> Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
> *******************Error detected during compile or link!*******************
> /home/zhangsijie1995/Documents/Package/petsc-3.18.3/src/snes/tutorials ex5f
> /opt/intel/oneapi/mpi/2021.8.0/bin/mpif90 -fPIC -Wall -ffree-line-length-none -ffree-line-length-0 -Wno-lto-type-mismatch -Wno-unused-dummy-argument -g -O0 -I/home/zhangsijie1995/Documents/Package/petsc-3.18.3/include -I/home/zhangsijie1995/Documents/Package/petsc-3.18.3/arch-linux-c-debug/include -I/opt/intel/oneapi/mkl/2023.0.0/include -I/opt/intel/oneapi/mpi/2021.8.0/include ex5f.F90 -Wl,-rpath,/home/zhangsijie1995/Documents/Package/petsc-3.18.3/arch-linux-c-debug/lib -L/home/zhangsijie1995/Documents/Package/petsc-3.18.3/arch-linux-c-debug/lib -Wl,-rpath,/opt/intel/oneapi/mkl/2023.0.0/lib/intel64 -L/opt/intel/oneapi/mkl/2023.0.0/lib/intel64 -Wl,-rpath,/home/zhangsijie1995/Documents/Package/petsc-3.18.3/I_MPI_SUBSTITUTE_INSTALLDIR/lib/release -L/home/zhangsijie1995/Documents/Package/petsc-3.18.3/I_MPI_SUBSTITUTE_INSTALLDIR/lib/release -Wl,-rpath,/home/zhangsijie1995/Documents/Package/petsc-3.18.3/I_MPI_SUBSTITUTE_INSTALLDIR/lib -L/home/zhangsijie1995/Documents/Package/petsc-3.18.3/I_MPI_SUBSTITUTE_INSTALLDIR/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/11 -L/usr/lib/gcc/x86_64-linux-gnu/11 -lpetsc -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lpthread -lm -lstdc++ -ldl -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl -o ex5f
> f951: Warning: Nonexistent include directory ‘I_MPI_SUBSTITUTE_INSTALLDIR/include/gfortran/11.1.0’ [-Wmissing-include-dirs]
> f951: Warning: Nonexistent include directory ‘I_MPI_SUBSTITUTE_INSTALLDIR/include’ [-Wmissing-include-dirs]
> Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process
> Number of SNES iterations = 3
> Completed test examples
> Error while running make check
> gmake[1]: *** [makefile:149: check] Error 1
> make: *** [GNUmakefile:17: check] Error 2<configure.log><make.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230111/3a420d1e/attachment.html>
