[petsc-users] GPU implementation of serial smoothers
Jed Brown jed at jedbrown.org
Tue Jan 10 13:47:51 CST 2023
The joy of GPUs. You can use sparse triangular kernels like ILU (provided by cuBLAS), but they are so mindbogglingly slow that you'll go back to the drawing board and try to use a multigrid method of some sort with polynomial/point-block smoothing.
BTW, on unstructured grids, coloring requires a lot of colors and thus many times more bandwidth (due to multiple passes) than the operator itself.
Mark Lohry <mlohry at gmail.com> writes:
> Well that's suboptimal. What are my options for 100% GPU solves with no
> host transfers?
> On Tue, Jan 10, 2023, 2:23 PM Barry Smith <bsmith at petsc.dev> wrote:
>> On Jan 10, 2023, at 2:19 PM, Mark Lohry <mlohry at gmail.com> wrote:
>> Is DILU a point-block method? We have -pc_type pbjacobi (and vpbjacobi if
>>> the node size is not uniform). The are good choices for scale-resolving CFD
>>> on GPUs.
>> I was hoping you'd know :)  pbjacobi is underperforming ilu by a pretty
>> wide margin on some of the systems i'm looking at.
>> We don't have colored smoothers currently in PETSc.
>> So what happens under the hood when I run -mg_levels_pc_type sor on GPU?
>> Are you actually decomposing the matrix into lower and computing updates
>> with matrix multiplications? Or is it just the standard serial algorithm
>> with thread safety ignored?
>>   It is running the regular SOR on the CPU and needs to copy up the vector
>> and copy down the result.
>>> if the node size is not uniform). The are good choices for scale-resolving
>>> CFD on GPUs.
>>> >> I'm running GAMG with CUDA, and I'm wondering how the nominally serial
>>> >> smoother algorithms are implemented on GPU? Specifically SOR/GS and
>>> ILU(0)
>>> >> -- in e.g. AMGx these are applied by first creating a coloring, and the
>>> >> smoother passes are done color by color. Is this how it's done in
>>> petsc AMG?
>>> >> Tangential, AMGx and OpenFOAM offer something called "DILU", diagonal
>>> ILU.
>>> >> Is there an equivalent in petsc?
>>> >> Thanks,
>>> >> Mark
