[petsc-users] GPU implementation of serial smoothers
Mark Lohry
mlohry at gmail.com
Tue Jan 10 13:36:39 CST 2023
Well that's suboptimal. What are my options for 100% GPU solves with no
host transfers?
On Tue, Jan 10, 2023, 2:23 PM Barry Smith <bsmith at petsc.dev> wrote:
> On Jan 10, 2023, at 2:19 PM, Mark Lohry <mlohry at gmail.com> wrote:
> Is DILU a point-block method? We have -pc_type pbjacobi (and vpbjacobi if
>> the node size is not uniform). The are good choices for scale-resolving CFD
>> on GPUs.
> I was hoping you'd know :) pbjacobi is underperforming ilu by a pretty
> wide margin on some of the systems i'm looking at.
> We don't have colored smoothers currently in PETSc.
> So what happens under the hood when I run -mg_levels_pc_type sor on GPU?
> Are you actually decomposing the matrix into lower and computing updates
> with matrix multiplications? Or is it just the standard serial algorithm
> with thread safety ignored?
> It is running the regular SOR on the CPU and needs to copy up the vector
> and copy down the result.
>> if the node size is not uniform). The are good choices for scale-resolving
>> CFD on GPUs.
>> > Mark Lohry <mlohry at gmail.com> writes:
>> >> I'm running GAMG with CUDA, and I'm wondering how the nominally serial
>> >> smoother algorithms are implemented on GPU? Specifically SOR/GS and
>> ILU(0)
>> >> -- in e.g. AMGx these are applied by first creating a coloring, and the
>> >> smoother passes are done color by color. Is this how it's done in
>> petsc AMG?
>> >> Tangential, AMGx and OpenFOAM offer something called "DILU", diagonal
>> ILU.
>> >> Is there an equivalent in petsc?
>> >> Thanks,
>> >> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230110/af4eda1d/attachment.html>
