[petsc-users] Vec Ownership ranges with Global Section Offsets
Nicholas Arnold-Medabalimi narnoldm at umich.edu
Fri Jan 6 09:09:58 CST 2023
Hi Matt
I apologize for any lack of clarity in the initial email.
looking at the initial output on rank 1
write(*,*) "cell",i,"offset",offset,'oStart',oStart, offset-oStart
cell           0 offset        2475 oStart        2640        -165
 cell           1 offset        2530 oStart        2640        -110
 cell           2 offset        2585 oStart        2640         -55
 cell           3 offset        2640 oStart        2640           0
cell          15 offset        -771 oStart        2640       -3411
cell 15 provides a negative offset because it is the overlap cell (that is
unowned)
The remained of cells are all owned. However, the first 3 cells (0,1,2)
return an offset that is less than the starting ownership range. I would
expect cell 0 to start at offset 2640 at minimum.
Sincerely
Nicholas
On Fri, Jan 6, 2023 at 10:05 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jan 6, 2023 at 9:56 AM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Apologies. If it helps, there is one cell of overlap in this small test
>> case for a 2D mesh that is 1 cell in height and a number of cells in
>> length. .
>> process 0
>>  Petsc VecGetLocalSize        2750
>>  size(stateVecV)        2750
>> process 1
>>  Petsc VecGetLocalSize        2640
>>  size(stateVecV)        2640
> The offsets shown below are well-within these sizes. I do not understand
> the problem.
>   Thanks,
>      Matt
>> On Fri, Jan 6, 2023 at 9:51 AM Matthew Knepley <knepley at gmail.com> wrote:
>>> On Fri, Jan 6, 2023 at 9:37 AM Nicholas Arnold-Medabalimi <
>>>> Hi Matt
>>>> I made a typo on the line statVecV(offset) = <set to something> in my
>>>> example, I agree. (I wrote that offhand since the actual assignment is much
>>>> larger) I should be statVecV(offset+1) = <assignment> so I'm confident it's
>>>> not a 1 0 indexing thing.
>>>> My question is more related to what is happening in the offsets. c0 and
>>>> c1 are pulled using DMplexgetheight stratum, so they are zero-indexed
>>>> (which is why I loop from c0 to (c1-1)).
>>>> For the size inquiries. on processor 0
>>>>  Petsc VecGetSize(stateVec)        5390
>>> I need to see VecGetLocalSize()
>>>   Matt
>>>> on processor 1
>>>> Petsc VecGetSize 5390
>>>> It's quite weird to me that processor one can have a positive offset
>>>> that is less than its starting ownership index (in the initial email
>>>> output).
>>>> Thanks for the assistance
>>>> Nicholas
>>>> On Fri, Jan 6, 2023 at 9:20 AM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Fri, Jan 6, 2023 at 2:28 AM Nicholas Arnold-Medabalimi <
>>>>>> Hi Petsc Users,
>>>>>> I'm working with a dmplex system with a subsampled mesh distributed
>>>>>> with an overlap of 1.
>>>>>> I'm encountering unusual situations when using VecGetOwnershipRange
>>>>>> to adjust the offset received from a global section. The logic of the
>>>>>> following code is first to get the offset needed to index a global vector
>>>>>> while still being able to check if it is an overlapped cell and skip if
>>>>>> needed while counting the owned cells.
>>>>>> call DMGetGlobalSection(dmplex,section,ierr)
>>>>>> call VecGetArrayF90(stateVec,stateVecV,ierr)
>>>>>> call VecGetOwnershipRange(stateVec,oStart,oEnd,ierr)
>>>>>> do i = c0, (c1-1)
>>>>>>     call PetscSectionGetOffset(section,i,offset,ierr)
>>>>>> oStart
>>>>>>     if(offset<0) then
>>>>>>         cycle
>>>>>>     endif
>>>>>> offset=offset-oStart
>>>>>> plexcells=plexcells+1
>>>>>> stateVecV(offset)= <set to something> enddo
>>>>>> I'm noticing some very weird results that I've appended below. The
>>>>>> GetOffset documentation notes that a negative offset indicates an unowned
>>>>>> point (which I use to cycle). However, the offset subtraction with oStart
>>>>>> will yield an illegal index for the Vector access. I see that on the
>>>>>> documentation for GetOwnershipRange, it notes that this may be
>>>>>> "ill-defined"  but I wanted to see if this is type of ill-defined I can
>>>>>> expect or there is just something terribly wrong with my PetscSection.(both
>>>>>> the Vec and Section were produced from DMPlexDistributeField so should by
>>>>>> definition have synchronized section information) I was wondering if there
>>>>>> is a possible output and/or the best way to index the vector. I'm thinking
>>>>>> of subtracting the offset of cell 0 perhaps?
>>>>> Can you show your vector sizes? Are you sure it is not the fact that
>>>>> F90 arrays use 1-based indices, but these are 0-based offsets?
>>>>>   Thanks,
>>>>>      Matt
>>>>>> on rank 0
>>>>>>  cell           0 offset           0 oStart           0           0
>>>>>>  cell           1 offset          55 oStart           0          55
>>>>>>  cell           2 offset         110 oStart           0         110
>>>>>>  cell           3 offset         165 oStart           0         165
>>>>>>  cell           4 offset         220 oStart           0         220
>>>>>>  cell           5 offset         275 oStart           0         275
>>>>>>  cell           6 offset         330 oStart           0         330
>>>>>>  cell           7 offset         385 oStart           0         385
>>>>>>  cell           8 offset         440 oStart           0         440
>>>>>>  cell           9 offset         495 oStart           0         495
>>>>>>  cell          10 offset         550 oStart           0         550
>>>>>>  cell          11 offset         605 oStart           0         605
>>>>>>  cell          12 offset         660 oStart           0         660
>>>>>>  cell          13 offset         715 oStart           0         715
>>>>>> and on rank one
>>>>>>  cell           4 offset        2695 oStart        2640          55
>>>>>>  cell           5 offset        2750 oStart        2640         110
>>>>>>  cell           6 offset        2805 oStart        2640         165
>>>>>>  cell           7 offset        2860 oStart        2640         220
>>>>>>  cell           8 offset        2915 oStart        2640         275
>>>>>>  cell           9 offset        2970 oStart        2640         330
>>>>>>  cell          10 offset        3025 oStart        2640         385
>>>>>>  cell          11 offset        3080 oStart        2640         440
>>>>>>  cell          12 offset        3135 oStart        2640         495
>>>>>>  cell          13 offset        3190 oStart        2640         550
>>>>>>  cell          14 offset        3245 oStart        2640         605
>>>>>> Sincerely
>>>>>> Nicholas
>>>>>> Ph.D. Candidate
>>>>>> Computational Aeroscience Lab
>>>>>> University of Michigan
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> Ph.D. Candidate
>>> experiments lead.
>>> -- Norbert Wiener
>> Ph.D. Candidate
> experiments lead.
> -- Norbert Wiener
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230106/66c9007d/attachment-0001.html>
