[petsc-users] Vec Ownership ranges with Global Section Offsets
Fri Jan 6 09:04:39 CST 2023
On Fri, Jan 6, 2023 at 9:56 AM Nicholas Arnold-Medabalimi <
narnoldm at umich.edu> wrote:
> Apologies. If it helps, there is one cell of overlap in this small test
> case for a 2D mesh that is 1 cell in height and a number of cells in
> length. .
> process 0
>  Petsc VecGetLocalSize        2750
>  size(stateVecV)        2750
> process 1
>  Petsc VecGetLocalSize        2640
>  size(stateVecV)        2640
The offsets shown below are well-within these sizes. I do not understand
the problem.
     Matt
> On Fri, Jan 6, 2023 at 9:51 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Jan 6, 2023 at 9:37 AM Nicholas Arnold-Medabalimi <
>>> Hi Matt
>>> I made a typo on the line statVecV(offset) = <set to something> in my
>>> example, I agree. (I wrote that offhand since the actual assignment is much
>>> larger) I should be statVecV(offset+1) = <assignment> so I'm confident it's
>>> not a 1 0 indexing thing.
>>> My question is more related to what is happening in the offsets. c0 and
>>> c1 are pulled using DMplexgetheight stratum, so they are zero-indexed
>>> (which is why I loop from c0 to (c1-1)).
>>> For the size inquiries. on processor 0
>>>  Petsc VecGetSize(stateVec)        5390
>> I need to see VecGetLocalSize()
>>   Matt
>>> on processor 1
>>> Petsc VecGetSize 5390
>>> It's quite weird to me that processor one can have a positive offset
>>> that is less than its starting ownership index (in the initial email
>>> output).
>>> Thanks for the assistance
>>> Nicholas
>>> On Fri, Jan 6, 2023 at 9:20 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Fri, Jan 6, 2023 at 2:28 AM Nicholas Arnold-Medabalimi <
>>>>> Hi Petsc Users,
>>>>> I'm working with a dmplex system with a subsampled mesh distributed
>>>>> with an overlap of 1.
>>>>> I'm encountering unusual situations when using VecGetOwnershipRange to
>>>>> adjust the offset received from a global section. The logic of the
>>>>> following code is first to get the offset needed to index a global vector
>>>>> while still being able to check if it is an overlapped cell and skip if
>>>>> needed while counting the owned cells.
>>>>> call DMGetGlobalSection(dmplex,section,ierr)
>>>>> call VecGetArrayF90(stateVec,stateVecV,ierr)
>>>>> call VecGetOwnershipRange(stateVec,oStart,oEnd,ierr)
>>>>> do i = c0, (c1-1)
>>>>>     call PetscSectionGetOffset(section,i,offset,ierr)
>>>>>     write(*,*) "cell",i,"offset",offset,'oStart',oStart, offset-oStart
>>>>>     if(offset<0) then
>>>>>         cycle
>>>>>     endif
>>>>> offset=offset-oStart
>>>>> plexcells=plexcells+1
>>>>> stateVecV(offset)= <set to something> enddo
>>>>> I'm noticing some very weird results that I've appended below. The
>>>>> GetOffset documentation notes that a negative offset indicates an unowned
>>>>> point (which I use to cycle). However, the offset subtraction with oStart
>>>>> will yield an illegal index for the Vector access. I see that on the
>>>>> documentation for GetOwnershipRange, it notes that this may be
>>>>> "ill-defined"  but I wanted to see if this is type of ill-defined I can
>>>>> expect or there is just something terribly wrong with my PetscSection.(both
>>>>> the Vec and Section were produced from DMPlexDistributeField so should by
>>>>> definition have synchronized section information) I was wondering if there
>>>>> is a possible output and/or the best way to index the vector. I'm thinking
>>>>> of subtracting the offset of cell 0 perhaps?
>>>> Can you show your vector sizes? Are you sure it is not the fact that
>>>> F90 arrays use 1-based indices, but these are 0-based offsets?
>>>>   Thanks,
>>>>      Matt
>>>>> on rank 0
>>>>>  cell           0 offset           0 oStart           0           0
>>>>>  cell           1 offset          55 oStart           0          55
>>>>>  cell           2 offset         110 oStart           0         110
>>>>>  cell           3 offset         165 oStart           0         165
>>>>>  cell           4 offset         220 oStart           0         220
>>>>>  cell           5 offset         275 oStart           0         275
>>>>>  cell           6 offset         330 oStart           0         330
>>>>>  cell           7 offset         385 oStart           0         385
>>>>>  cell           8 offset         440 oStart           0         440
>>>>>  cell           9 offset         495 oStart           0         495
>>>>>  cell          10 offset         550 oStart           0         550
>>>>>  cell          11 offset         605 oStart           0         605
>>>>>  cell          12 offset         660 oStart           0         660
>>>>>  cell          13 offset         715 oStart           0         715
>>>>> and on rank one
>>>>> cell           0 offset        2475 oStart        2640        -165
>>>>>  cell           1 offset        2530 oStart        2640        -110
>>>>>  cell           2 offset        2585 oStart        2640         -55
>>>>>  cell           3 offset        2640 oStart        2640           0
>>>>>  cell           4 offset        2695 oStart        2640          55
>>>>>  cell           5 offset        2750 oStart        2640         110
>>>>>  cell           6 offset        2805 oStart        2640         165
>>>>>  cell           7 offset        2860 oStart        2640         220
>>>>>  cell           8 offset        2915 oStart        2640         275
>>>>>  cell           9 offset        2970 oStart        2640         330
>>>>>  cell          10 offset        3025 oStart        2640         385
>>>>>  cell          11 offset        3080 oStart        2640         440
>>>>>  cell          12 offset        3135 oStart        2640         495
>>>>>  cell          13 offset        3190 oStart        2640         550
>>>>>  cell          14 offset        3245 oStart        2640         605
>>>>>  cell          15 offset        -771 oStart        2640       -3411
>>>>> Sincerely
>>>>> Nicholas
>>>>> Ph.D. Candidate
>>>>> Computational Aeroscience Lab
>>>>> University of Michigan
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> Ph.D. Candidate
>> experiments lead.
>> -- Norbert Wiener
> Ph.D. Candidate
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230106/f9f1b2be/attachment.html>
