[petsc-users] setting a vector with VecSetValue versus VecSetValues
Junchao Zhang
junchao.zhang at gmail.com
Thu Jan 5 11:37:49 CST 2023
VecSetValue() also needs global indices, so you need PetscInt gl_row = (
PetscInt)(i)+rstart;
--Junchao Zhang
On Thu, Jan 5, 2023 at 11:25 AM Alfredo Jaramillo <ajaramillopalma at gmail.com>
wrote:
> dear PETSc developers,
> I have a code where I copy an array to a distributed petsc vector with the
> next lines:
> 1 for (int i = 0; i < ndof_local; i++) {
> 2 PetscInt gl_row = (PetscInt)(i)+rstart;
> 3 PetscScalar val = (PetscScalar)u[i];
> 4 VecSetValues(x,1,&gl_row,&val,INSERT_VALUES);
> 5 }
> // for (int i = 0; i < ndof_local; i++) {
> // PetscInt gl_row = (PetscInt)(i);
> // PetscScalar val = (PetscScalar)u[i];
> // VecSetValue(x,gl_row,val,INSERT_VALUES);
> VecAssemblyBegin(x);
> VecAssemblyEnd(x);
> This works as expected. If, instead of using lines 1-5, I use the lines
> where VecSetValue is used with local indices, then the vector is null on
> all the processes but rank 0, and the piece of information at rank zero is
> incorrect.
> What could I be doing wrong?
> bests regards
> Alfredo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230105/936a1759/attachment.html>
