[petsc-users] setting a vector with VecSetValue versus VecSetValues
Alfredo Jaramillo
ajaramillopalma at gmail.com
Thu Jan 5 11:25:08 CST 2023
dear PETSc developers,
I have a code where I copy an array to a distributed petsc vector with the
next lines:
1 for (int i = 0; i < ndof_local; i++) {
2 PetscInt gl_row = (PetscInt)(i)+rstart;
3 PetscScalar val = (PetscScalar)u[i];
4 VecSetValues(x,1,&gl_row,&val,INSERT_VALUES);
5 }
// for (int i = 0; i < ndof_local; i++) {
// PetscInt gl_row = (PetscInt)(i);
// PetscScalar val = (PetscScalar)u[i];
// VecSetValue(x,gl_row,val,INSERT_VALUES);
VecAssemblyBegin(x);
VecAssemblyEnd(x);
This works as expected. If, instead of using lines 1-5, I use the lines
where VecSetValue is used with local indices, then the vector is null on
all the processes but rank 0, and the piece of information at rank zero is
incorrect.
What could I be doing wrong?
bests regards
Alfredo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230105/994b4708/attachment.html>
