[petsc-users] HYPRE requires C++ compiler
Pierre Jolivet pierre at joliv.et
Mon Feb 20 22:28:17 CST 2023
> On 21 Feb 2023, at 4:07 AM, Park, Heeho via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi PETSc developers,
> I’m using the same configure script on my system to compile petsc-main branch as petsc-v3.17.2, but now I am receiving this message.
> I’ve tried it several different ways but HYPRE installer does not recognize the mpicxx I’m using. I can send you the configure log and file if you would like to see them.
Send those files to petsc-maint at mcs.anl.gov
Pierre
>               Trying to download https://github.com/hypre-space/hypre for HYPRE
>            UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
>                       Error: Hypre requires C++ compiler. None specified
> Currently Loaded Modules:
>   1) intel/21.3.0   2) mkl/21.3.0   3) openmpi-intel/4.0   4) anaconda3/5.2.0   5) gcc/4.9.3
> Thanks,
> Heeho D. Park, Ph.D.
>    Computational Hydrologist & Nuclear Engineer
>     Center for Energy & Earth Systems
>     Applied Systems Analysis and Research Dept.
>    Sandia National Laboratories
>    Email: heepark at sandia.gov
>    Web: Homepage
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230221/2052b562/attachment-0001.html>
