[petsc-users] Inquiry regarding DMAdaptLabel function
Zongze Yang
yangzongze at gmail.com
Sat Feb 18 01:24:51 CST 2023
Dear PETSc Group,
I am writing to inquire about the function DMAdaptLabel in PETSc.
I am trying to use it coarse a mesh, but the resulting mesh is refined.
In the following code, all of the `adpat` label values were set to 2
(DM_ADAPT_COARSEN).
There must be something wrong. Could you give some suggestions?
```python
from firedrake import *
from firedrake.petsc import PETSc
def mark_all_cells(mesh):
plex = mesh.topology_dm
with PETSc.Log.Event("ADD_ADAPT_LABEL"):
plex.createLabel('adapt')
cs, ce = plex.getHeightStratum(0)
for i in range(cs, ce):
plex.setLabelValue('adapt', i, 2)
return plex
mesh = RectangleMesh(10, 10, 1, 1)
x = SpatialCoordinate(mesh)
V = FunctionSpace(mesh, 'CG', 1)
f = Function(V).interpolate(10 + 10*sin(x[0]))
triplot(mesh)
plex = mark_all_cells(mesh)
new_plex = plex.adaptLabel('adapt')
mesh = Mesh(new_plex)
triplot(mesh)
Thank you very much for your time.
Best wishes,
Zongze
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230218/5b6b2277/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230218/5b6b2277/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230218/5b6b2277/attachment-0003.png>
