[petsc-users] dmplex overlap questions
    Matthew Knepley
    knepley at gmail.com
    Thu Feb 16 16:00:05 CST 2023
On Thu, Feb 16, 2023 at 1:09 PM Lawrence Mitchell <wence at gmx.li> wrote:
> On Thu, 16 Feb 2023 at 16:43, Matthew Knepley <knepley at gmail.com> wrote:
> > On Thu, Feb 16, 2023 at 10:54 AM Lawrence Mitchell <wence at gmx.li> wrote:
> >> Hi Blaise,
> >> On Thu, 16 Feb 2023 at 15:17, Blaise Bourdin <bourdin at mcmaster.ca>
> wrote:
> >> > Hi,
> >> > I am trying to implement a non-local finite elements reconstruction
> operator in parallel.
> >> > Given a dmplex distributed with an overlap, is there a way to figure
> out which cells are in the overlap and which are not?
> >> Yes. Get the pointSF of the DM, and the cell chart
> >> DMPlexGetPointSF(dm, &sf);
> >> DMPlexGetHeightStratum(dm, 0, &cstart, &cend);
> >> Now get the graph (specifically ilocal of the sf):
> >> PetscSFGetGraph(sf, NULL, &nleaves, &ilocal,  NULL);
> >> Now any value of ilocal that lies in [cstart, cend) is a cell which is
> >> not owned by this process (i.e. in the overlap). Note that ilocal can
> >> be NULL which just means it is the identity map [0, ..., nleaves), so
> >> you just intersect [cstart, cend) with [0, nleaves) in that case to
> >> find the overlap cells.
> >> But that is very unlikely to be true, so:
> > Note that you can use
> >   PetscFindInt(nleaves, ilocal, cell, &loc);
> Modulo argument order, is it not PetscFindInt(cell, nleaves, ilocal, &loc)?
You are right.
> I guess one should probably document that PetscSFSetGraph ensures that
> ilocal is sorted.
Yes, I thought it was already there, but does not seem so.
    Matt
> Lawrence
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230216/600baa0b/attachment.html>
