[petsc-users] dmplex overlap questions
    Lawrence Mitchell
    wence at gmx.li
    Thu Feb 16 12:09:00 CST 2023
On Thu, 16 Feb 2023 at 16:43, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Feb 16, 2023 at 10:54 AM Lawrence Mitchell <wence at gmx.li> wrote:
>> Hi Blaise,
>> On Thu, 16 Feb 2023 at 15:17, Blaise Bourdin <bourdin at mcmaster.ca> wrote:
>> > Hi,
>> > I am trying to implement a non-local finite elements reconstruction operator in parallel.
>> > Given a dmplex distributed with an overlap, is there a way to figure out which cells are in the overlap and which are not?
>> Yes. Get the pointSF of the DM, and the cell chart
>> DMPlexGetPointSF(dm, &sf);
>> DMPlexGetHeightStratum(dm, 0, &cstart, &cend);
>> Now get the graph (specifically ilocal of the sf):
>> PetscSFGetGraph(sf, NULL, &nleaves, &ilocal,  NULL);
>> Now any value of ilocal that lies in [cstart, cend) is a cell which is
>> not owned by this process (i.e. in the overlap). Note that ilocal can
>> be NULL which just means it is the identity map [0, ..., nleaves), so
>> you just intersect [cstart, cend) with [0, nleaves) in that case to
>> find the overlap cells.
>> But that is very unlikely to be true, so:
> Note that you can use
>   PetscFindInt(nleaves, ilocal, cell, &loc);
Modulo argument order, is it not PetscFindInt(cell, nleaves, ilocal, &loc)?
I guess one should probably document that PetscSFSetGraph ensures that
ilocal is sorted.
Lawrence
