[petsc-users] Problem setting Fieldsplit fields
Matthew Knepley
knepley at gmail.com
Tue Feb 14 08:55:24 CST 2023
On Tue, Feb 14, 2023 at 8:36 AM Nicolas Barnafi <nbarnafi at cmm.uchile.cl>
wrote:
> Hello Matt,
> After some discussions elsewhere (thanks @LMitchell!), we found out that
> the problem is that the fields are setup with PCSetIS, without an attached
> DM, which does not support this kind of nesting fields.
> I would like to add this feature, meaning that during the setup of the
> preconditioner there should be an additional routine when there is no dm
> that reads _%i_fields and sets the corresponding fields to the sub PCs, in
> some order.
> My plan would be to do so at the PCSetUp_FieldSplit level. The idea is
> that whenever some IS fields are set such as 'a' and 'b', it should be
> possible to rearrange them with '-pc_fieldsplit_0_fields a,b' , or at least
> support this with numbered fields.
> How do you see it?
Just to clarify, if you call SetIS() 3 times, and then give
-pc_fieldsplit_0_fields 0,2
then we should reduce the number of fields to two by calling
ISConcatenate() on the first and last ISes?
I think this should not be hard. It will work exactly as it does on the DM
case, except the ISes will come from
the PC, not the DM. One complication is that you will have to hold the new
ISes until the end, and then set them.
Matt
> Best,
> NB
> On 06/02/23 17:57, Matthew Knepley wrote:
> On Mon, Feb 6, 2023 at 11:45 AM Nicolas Barnafi <nbarnafi at cmm.uchile.cl>
> wrote:
>> Thank you Matt,
>> Again, at the bottom of this message you will find the -info output. I
>> don't see any output related to the fields,
> If the splits were done automatically, you would see an info message from
> here:
> https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/fieldsplit/fieldsplit.c#L1595
> Thus it must be setup here
> https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/fieldsplit/fieldsplit.c#L380
> There are info statements, but you do not see them, I do not see a way
> around using a small example
> to understand how you are setting up the system, since it is working as
> expected in the PETSc examples.
> Thanks,
> Matt
>> Best
>> ------ -info
>> [0] <sys> PetscDetermineInitialFPTrap(): Floating point trapping is on by
>> default 13
>> [0] <sys> PetscDeviceInitializeTypeFromOptions_Private(): PetscDeviceType
>> host available, initializing
>> host initialized, default device id 0, view FALSE, init type lazy
>> cuda not available
>> hip not available
>> sycl not available
>> [0] <sys> PetscInitialize_Common(): PETSc successfully started: number of
>> processors = 1
>> [0] <sys> PetscGetHostName(): Rejecting domainname, likely is NIS
>> nico-santech.(none)
>> [0] <sys> PetscInitialize_Common(): Running on machine: nico-santech
>> [0] <sys> SlepcInitialize(): SLEPc successfully started
>> [0] <sys> PetscCommDuplicate(): Duplicating a communicator 94770066936960
>> 94770087780768 max tags = 2147483647
>> [0] <sys> Petsc_OuterComm_Attr_Delete_Fn(): Removing reference to PETSc
>> communicator embedded in a user MPI_Comm 94770087780768
>> [0] <sys> Petsc_InnerComm_Attr_Delete_Fn(): User MPI_Comm 94770066936960
>> is being unlinked from inner PETSc comm 94770087780768
>> [0] <sys> PetscCommDestroy(): Deleting PETSc MPI_Comm 94770087780768
>> [0] <sys> Petsc_Counter_Attr_Delete_Fn(): Deleting counter data in an
>> [0] <sys> PetscCommDuplicate(): Using internal PETSc communicator
>> 94770066936960 94770087780768
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 1219 X 1219; storage
>> space: 0 unneeded,26443 used
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Number of mallocs during
>> MatSetValues() is 0
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 150
>> [0] <mat> MatCheckCompressedRow(): Found the ratio (num_zerorows
>> 0)/(num_localrows 1219) < 0.6. Do not use CompressedRow routines.
>> [0] <mat> MatSeqAIJCheckInode(): Found 1160 nodes out of 1219 rows. Not
>> using Inode routines
>> nico-santech.(none)
>> [0] <pc> PCSetUp(): Setting up PC for first time
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 615 X 615; storage space:
>> 0 unneeded,9213 used
>> MatSetValues() is 0
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 117
>> 0)/(num_localrows 615) < 0.6. Do not use CompressedRow routines.
>> [0] <mat> MatSeqAIJCheckInode(): Found 561 nodes out of 615 rows. Not
>> [0] <sys> PetscCommDuplicate(): Duplicating a communicator 94770066934048
>> 94770110251424 max tags = 2147483647
>> communicator embedded in a user MPI_Comm 94770110251424
>> [0] <sys> Petsc_InnerComm_Attr_Delete_Fn(): User MPI_Comm 94770066934048
>> is being unlinked from inner PETSc comm 94770110251424
>> [0] <sys> PetscCommDestroy(): Deleting PETSc MPI_Comm 94770110251424
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 64 X 64; storage space: 0
>> unneeded,0 used
>> MatSetValues() is 0
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 0
>> 64)/(num_localrows 64) > 0.6. Use CompressedRow routines.
>> [0] <mat> MatSeqAIJCheckInode(): Found 13 nodes of 64. Limit used: 5.
>> Using Inode routines
>> 94770100861088 max tags = 2147483647
>> communicator embedded in a user MPI_Comm 94770100861088
>> is being unlinked from inner PETSc comm 94770100861088
>> [0] <sys> PetscCommDestroy(): Deleting PETSc MPI_Comm 94770100861088
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 240 X 240; storage space:
>> 0 unneeded,2140 used
>> MatSetValues() is 0
>> 0)/(num_localrows 240) < 0.6. Do not use CompressedRow routines.
>> [0] <mat> MatSeqAIJCheckInode(): Found 235 nodes out of 240 rows. Not
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 300 X 300; storage space:
>> 0 unneeded,2292 used
>> MatSetValues() is 0
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 33
>> 0)/(num_localrows 300) < 0.6. Do not use CompressedRow routines.
>> [0] <mat> MatSeqAIJCheckInode(): Found 300 nodes out of 300 rows. Not
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 615 X 1219; storage
>> space: 0 unneeded,11202 used
>> MatSetValues() is 0
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 64 X 1219; storage space:
>> 0 unneeded,288 used
>> MatSetValues() is 0
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 6
>> 0)/(num_localrows 64) < 0.6. Do not use CompressedRow routines.
>> [0] <mat> MatSeqAIJCheckInode(): Found 64 nodes out of 64 rows. Not using
>> Inode routines
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 240 X 1219; storage
>> space: 0 unneeded,8800 used
>> MatSetValues() is 0
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 78
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 300 X 1219; storage
>> space: 0 unneeded,6153 used
>> MatSetValues() is 0
>> [0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 89
>> 94770066934048 94770100861088
>> 0 KSP Residual norm 2.541418258630e+01
>> [0] <ksp> KSPConvergedDefault(): user has provided nonzero initial guess,
>> computing 2-norm of RHS
>> [0] <pc> PCSetUp(): Leaving PC with identical preconditioner since
>> operator is unchanged
>> 94770066934048 947701008610882
>> On 03/02/23 21:11, Matthew Knepley wrote:
>> On Fri, Feb 3, 2023 at 3:03 PM Nicolas Barnafi <nbarnafi at cmm.uchile.cl>
>> wrote:
>>> > There are a number of common errors:
>>> > 1) Your PC has a prefix
>>> > 2) You have not called KSPSetFromOptions() here
>>> > Can you send the -ksp_view output?
>>> The PC at least has no prefix. I had to set ksp_rtol to 1 to get through
>>> the solution process, you will find both the petsc_rc and the ksp_view
>>> at the bottom of this message.
>>> Options are indeed being set from the options file, but there must be
>>> something missing at a certain level. Thanks for looking into this.
>> Okay, the next step is to pass
>> -info
>> and send the output. This will tell us how the default splits were done.
>> If that
>> is not conclusive, we will have to use the debugger.
>> Thanks,
>> Matt
>>> Best
>>> ---- petsc_rc file
>>> -ksp_monitor
>>> -ksp_type gmres
>>> -ksp_view
>>> -mat_type aij
>>> -ksp_norm_type unpreconditioned
>>> -ksp_atol 1e-14
>>> -ksp_rtol 1
>>> -pc_type fieldsplit
>>> -pc_fieldsplit_type multiplicative
>>> ---- ksp_view
>>> KSP Object: 1 MPI process
>>> type: gmres
>>> restart=500, using Classical (unmodified) Gram-Schmidt
>>> Orthogonalization with no iterative refinement
>>> happy breakdown tolerance 1e-30
>>> maximum iterations=10000, nonzero initial guess
>>> tolerances: relative=1., absolute=1e-14, divergence=10000.
>>> right preconditioning
>>> using UNPRECONDITIONED norm type for convergence test
>>> PC Object: 1 MPI process
>>> type: fieldsplit
>>> FieldSplit with MULTIPLICATIVE composition: total splits = 4
>>> Solver info for each split is in the following KSP objects:
>>> Split number 0 Defined by IS
>>> KSP Object: (fieldsplit_0_) 1 MPI process
>>> type: preonly
>>> maximum iterations=10000, initial guess is zero
>>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>>> left preconditioning
>>> using DEFAULT norm type for convergence test
>>> PC Object: (fieldsplit_0_) 1 MPI process
>>> type: ilu
>>> PC has not been set up so information may be incomplete
>>> out-of-place factorization
>>> 0 levels of fill
>>> tolerance for zero pivot 2.22045e-14
>>> matrix ordering: natural
>>> matrix solver type: petsc
>>> matrix not yet factored; no additional information available
>>> linear system matrix = precond matrix:
>>> Mat Object: (fieldsplit_0_) 1 MPI process
>>> type: seqaij
>>> rows=615, cols=615
>>> total: nonzeros=9213, allocated nonzeros=9213
>>> total number of mallocs used during MatSetValues calls=0
>>> not using I-node routines
>>> Split number 1 Defined by IS
>>> KSP Object: (fieldsplit_1_) 1 MPI process
>>> type: preonly
>>> PC Object: (fieldsplit_1_) 1 MPI process
>>> type: ilu
>>> 0 levels of fill
>>> Mat Object: (fieldsplit_1_) 1 MPI process
>>> type: seqaij
>>> rows=64, cols=64
>>> total: nonzeros=0, allocated nonzeros=0
>>> using I-node routines: found 13 nodes, limit used is 5
>>> Split number 2 Defined by IS
>>> KSP Object: (fieldsplit_2_) 1 MPI process
>>> type: preonly
>>> PC Object: (fieldsplit_2_) 1 MPI process
>>> type: ilu
>>> 0 levels of fill
>>> Mat Object: (fieldsplit_2_) 1 MPI process
>>> type: seqaij
>>> rows=240, cols=240
>>> total: nonzeros=2140, allocated nonzeros=2140
>>> Split number 3 Defined by IS
>>> KSP Object: (fieldsplit_3_) 1 MPI process
>>> type: preonly
>>> PC Object: (fieldsplit_3_) 1 MPI process
>>> type: ilu
>>> 0 levels of fill
>>> Mat Object: (fieldsplit_3_) 1 MPI process
>>> type: seqaij
>>> rows=300, cols=300
>>> total: nonzeros=2292, allocated nonzeros=2292
>>> Mat Object: 1 MPI process
>>> type: seqaij
>>> rows=1219, cols=1219
>>> total: nonzeros=26443, allocated nonzeros=26443
>>> solving time: 0.00449609
>>> iterations: 0
>>> estimated error: 25.4142
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230214/bcfacddd/attachment-0001.html>
