[petsc-users] Problem setting Fieldsplit fields
Nicolas Barnafi
nbarnafi at cmm.uchile.cl
Tue Feb 14 07:36:34 CST 2023
Hello Matt,
After some discussions elsewhere (thanks @LMitchell!), we found out that
the problem is that the fields are setup with PCSetIS, without an
attached DM, which does not support this kind of nesting fields.
I would like to add this feature, meaning that during the setup of the
preconditioner there should be an additional routine when there is no dm
that reads _%i_fields and sets the corresponding fields to the sub PCs,
in some order.
My plan would be to do so at the PCSetUp_FieldSplit level. The idea is
that whenever some IS fields are set such as 'a' and 'b', it should be
possible to rearrange them with '-pc_fieldsplit_0_fields a,b' , or at
least support this with numbered fields.
How do you see it?
Best,
NB
On 06/02/23 17:57, Matthew Knepley wrote:
> On Mon, Feb 6, 2023 at 11:45 AM Nicolas Barnafi
> <nbarnafi at cmm.uchile.cl> wrote:
> Thank you Matt,
> Again, at the bottom of this message you will find the -info
> output. I don't see any output related to the fields,
> If the splits were done automatically, you would see an info message
> from here:
> https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/fieldsplit/fieldsplit.c#L1595
> Thus it must be setup here
> https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/fieldsplit/fieldsplit.c#L380
> There are info statements, but you do not see them, I do not see a way
> around using a small example
> to understand how you are setting up the system, since it is working
> as expected in the PETSc examples.
> Thanks,
> Matt
> Best
> ------ -info
> [0] <sys> PetscDetermineInitialFPTrap(): Floating point trapping
> is on by default 13
> [0] <sys> PetscDeviceInitializeTypeFromOptions_Private():
> PetscDeviceType host available, initializing
> PetscDevice host initialized, default device id 0, view FALSE,
> init type lazy
> PetscDeviceType cuda not available
> PetscDeviceType hip not available
> PetscDeviceType sycl not available
> [0] <sys> PetscInitialize_Common(): PETSc successfully started:
> number of processors = 1
> [0] <sys> PetscGetHostName(): Rejecting domainname, likely is NIS
> nico-santech.(none)
> [0] <sys> PetscInitialize_Common(): Running on machine: nico-santech
> [0] <sys> SlepcInitialize(): SLEPc successfully started
> [0] <sys> PetscCommDuplicate(): Duplicating a communicator
> 94770066936960 94770087780768 max tags = 2147483647
> [0] <sys> Petsc_OuterComm_Attr_Delete_Fn(): Removing reference to
> PETSc communicator embedded in a user MPI_Comm 94770087780768
> [0] <sys> Petsc_InnerComm_Attr_Delete_Fn(): User MPI_Comm
> 94770066936960 is being unlinked from inner PETSc comm 94770087780768
> [0] <sys> PetscCommDestroy(): Deleting PETSc MPI_Comm 94770087780768
> [0] <sys> Petsc_Counter_Attr_Delete_Fn(): Deleting counter data in
> an MPI_Comm 94770087780768
> [0] <sys> PetscCommDuplicate(): Using internal PETSc communicator
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 1219 X 1219;
> storage space: 0 unneeded,26443 used
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Number of mallocs during
> MatSetValues() is 0
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 150
> [0] <mat> MatCheckCompressedRow(): Found the ratio (num_zerorows
> 0)/(num_localrows 1219) < 0.6. Do not use CompressedRow routines.
> [0] <mat> MatSeqAIJCheckInode(): Found 1160 nodes out of 1219
> rows. Not using Inode routines
> nico-santech.(none)
> [0] <pc> PCSetUp(): Setting up PC for first time
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 615 X 615; storage
> space: 0 unneeded,9213 used
> MatSetValues() is 0
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 117
> 0)/(num_localrows 615) < 0.6. Do not use CompressedRow routines.
> [0] <mat> MatSeqAIJCheckInode(): Found 561 nodes out of 615 rows.
> 94770066934048 94770110251424 max tags = 2147483647
> PETSc communicator embedded in a user MPI_Comm 94770110251424
> 94770066934048 is being unlinked from inner PETSc comm 94770110251424
> [0] <sys> PetscCommDestroy(): Deleting PETSc MPI_Comm 94770110251424
> an MPI_Comm 94770110251424
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 64 X 64; storage
> space: 0 unneeded,0 used
> MatSetValues() is 0
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 0
> 64)/(num_localrows 64) > 0.6. Use CompressedRow routines.
> [0] <mat> MatSeqAIJCheckInode(): Found 13 nodes of 64. Limit used:
> 5. Using Inode routines
> 94770066934048 94770100861088 max tags = 2147483647
> PETSc communicator embedded in a user MPI_Comm 94770100861088
> 94770066934048 is being unlinked from inner PETSc comm 94770100861088
> [0] <sys> PetscCommDestroy(): Deleting PETSc MPI_Comm 94770100861088
> an MPI_Comm 94770100861088
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 240 X 240; storage
> space: 0 unneeded,2140 used
> MatSetValues() is 0
> 0)/(num_localrows 240) < 0.6. Do not use CompressedRow routines.
> [0] <mat> MatSeqAIJCheckInode(): Found 235 nodes out of 240 rows.
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 300 X 300; storage
> space: 0 unneeded,2292 used
> MatSetValues() is 0
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 33
> 0)/(num_localrows 300) < 0.6. Do not use CompressedRow routines.
> [0] <mat> MatSeqAIJCheckInode(): Found 300 nodes out of 300 rows.
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 615 X 1219;
> storage space: 0 unneeded,11202 used
> MatSetValues() is 0
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 64 X 1219; storage
> space: 0 unneeded,288 used
> MatSetValues() is 0
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 6
> 0)/(num_localrows 64) < 0.6. Do not use CompressedRow routines.
> [0] <mat> MatSeqAIJCheckInode(): Found 64 nodes out of 64 rows.
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 240 X 1219;
> storage space: 0 unneeded,8800 used
> MatSetValues() is 0
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 78
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 300 X 1219;
> storage space: 0 unneeded,6153 used
> MatSetValues() is 0
> [0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 89
> 0 KSP Residual norm 2.541418258630e+01
> [0] <ksp> KSPConvergedDefault(): user has provided nonzero initial
> guess, computing 2-norm of RHS
> [0] <pc> PCSetUp(): Leaving PC with identical preconditioner since
> operator is unchanged
> 94770066934048 947701008610882
> On 03/02/23 21:11, Matthew Knepley wrote:
>> On Fri, Feb 3, 2023 at 3:03 PM Nicolas Barnafi
>> > There are a number of common errors:
>> > 1) Your PC has a prefix
>> > 2) You have not called KSPSetFromOptions() here
>> > Can you send the -ksp_view output?
>> The PC at least has no prefix. I had to set ksp_rtol to 1 to
>> get through
>> the solution process, you will find both the petsc_rc and the
>> ksp_view
>> at the bottom of this message.
>> Options are indeed being set from the options file, but there
>> must be
>> something missing at a certain level. Thanks for looking into
>> this.
>> Okay, the next step is to pass
>> -info
>> and send the output. This will tell us how the default splits
>> were done. If that
>> is not conclusive, we will have to use the debugger.
>> Thanks,
>> Matt
>> Best
>> ---- petsc_rc file
>> -ksp_monitor
>> -ksp_type gmres
>> -ksp_view
>> -mat_type aij
>> -ksp_norm_type unpreconditioned
>> -ksp_atol 1e-14
>> -ksp_rtol 1
>> -pc_type fieldsplit
>> -pc_fieldsplit_type multiplicative
>> ---- ksp_view
>> KSP Object: 1 MPI process
>> type: gmres
>> restart=500, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>> happy breakdown tolerance 1e-30
>> maximum iterations=10000, nonzero initial guess
>> tolerances: relative=1., absolute=1e-14, divergence=10000.
>> right preconditioning
>> using UNPRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI process
>> type: fieldsplit
>> FieldSplit with MULTIPLICATIVE composition: total splits = 4
>> Solver info for each split is in the following KSP objects:
>> Split number 0 Defined by IS
>> KSP Object: (fieldsplit_0_) 1 MPI process
>> type: preonly
>> maximum iterations=10000, initial guess is zero
>> tolerances: relative=1e-05, absolute=1e-50,
>> divergence=10000.
>> left preconditioning
>> using DEFAULT norm type for convergence test
>> PC Object: (fieldsplit_0_) 1 MPI process
>> type: ilu
>> PC has not been set up so information may be incomplete
>> out-of-place factorization
>> 0 levels of fill
>> tolerance for zero pivot 2.22045e-14
>> matrix ordering: natural
>> matrix solver type: petsc
>> matrix not yet factored; no additional information
>> available
>> linear system matrix = precond matrix:
>> Mat Object: (fieldsplit_0_) 1 MPI process
>> type: seqaij
>> rows=615, cols=615
>> total: nonzeros=9213, allocated nonzeros=9213
>> total number of mallocs used during MatSetValues calls=0
>> not using I-node routines
>> Split number 1 Defined by IS
>> KSP Object: (fieldsplit_1_) 1 MPI process
>> type: preonly
>> divergence=10000.
>> PC Object: (fieldsplit_1_) 1 MPI process
>> type: ilu
>> 0 levels of fill
>> available
>> Mat Object: (fieldsplit_1_) 1 MPI process
>> type: seqaij
>> rows=64, cols=64
>> total: nonzeros=0, allocated nonzeros=0
>> using I-node routines: found 13 nodes, limit used is 5
>> Split number 2 Defined by IS
>> KSP Object: (fieldsplit_2_) 1 MPI process
>> type: preonly
>> divergence=10000.
>> PC Object: (fieldsplit_2_) 1 MPI process
>> type: ilu
>> 0 levels of fill
>> available
>> Mat Object: (fieldsplit_2_) 1 MPI process
>> type: seqaij
>> rows=240, cols=240
>> total: nonzeros=2140, allocated nonzeros=2140
>> Split number 3 Defined by IS
>> KSP Object: (fieldsplit_3_) 1 MPI process
>> type: preonly
>> divergence=10000.
>> PC Object: (fieldsplit_3_) 1 MPI process
>> type: ilu
>> 0 levels of fill
>> available
>> Mat Object: (fieldsplit_3_) 1 MPI process
>> type: seqaij
>> rows=300, cols=300
>> total: nonzeros=2292, allocated nonzeros=2292
>> Mat Object: 1 MPI process
>> type: seqaij
>> rows=1219, cols=1219
>> total: nonzeros=26443, allocated nonzeros=26443
>> solving time: 0.00449609
>> iterations: 0
>> estimated error: 25.4142
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230214/1fcb9615/attachment-0001.html>
