[petsc-users] KSP_Solve crashes in debug mode
Sajid Ali Syed
sasyed at fnal.gov
Thu Feb 9 11:42:02 CST 2023
Hi PETSc-developers,
In our application we call KSP_Solve as part of a step to propagate a beam through a lattice. I am observing a crash within KSP_Solve for an application only after the 43rd call to KSP_Solve when building the application and PETSc in debug mode, full logs for which are attached with this email (1 MPI rank and 4 OMP threads were used, but this crash occurs with multiple MPI ranks as well ). I am also including the last few lines of the configuration for this build. This crash does not occur when building the application and PETSc in release mode.
Could someone tell me what causes this crash and if anything can be done to prevent it? Thanks in advance.
The configuration of this solver is here : https://github.com/fnalacceleratormodeling/synergia2/blob/sajid/features/openpmd_basic_integration/src/synergia/collective/space_charge_3d_fd_utils.cc#L273-L292
Thank You,
Sajid Ali (he/him) | Research Associate
Scientific Computing Division
Fermi National Accelerator Laboratory
s-sajid-ali.github.io<http://s-sajid-ali.github.io>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230209/754cb632/attachment-0001.html>
Desc: ksp_crash_log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230209/754cb632/attachment-0001.obj>
