[petsc-users] DMPlex Reordering
Wed Feb 8 19:26:42 CST 2023
On Wed, Feb 8, 2023 at 7:50 PM Nicholas Arnold-Medabalimi <
narnoldm at umich.edu> wrote:
> Hi Matt
> Could you clarify what DMPlexOrient is doing as far as the metric for
> compatibility for orientation?
It makes sure that the orientation of k-faces agree across processes
(through the SF). If faces are created
in parallel, without communication, there is no guarantee that both sides
choose the same orientation.
It also orients the serial edges, so you can throw in an un-oriented mesh
and it will fix it.
     Matt
> Sincerely
> Nicholas
> On Mon, Jul 25, 2022 at 11:54 AM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Jul 25, 2022 at 10:11 AM Nicholas Arnold-Medabalimi <
>>> Hi Petsc users,
>>> I have been working on how to read in meshes into a DMPlex object. The
>>> process of building the cones has been relatively straightforward. The mesh
>>> files in question have sets of faces that I use to derive the cell vertex
>>> cones. The method is basically identical to that used in
>>> DMPlexCreateFluent. After I setup the DMPlex cones and call Symmetrize and
>>> Stratify, I then load in all the coordinates corresponding to the
>>> vertices and then use DMInterpolate to generate the intermediate edges
>>> The issue that I am running into is that because I am deriving the
>>> cell-vertex relationship from independent sets of face-vertex
>>> relationships, I can end up with cells that have improper mesh ordering.
>>> For example a cell with the coordinates:
>>> point 0: 0.000000 0.000000
>>> point 1: 0.000000 2.500000
>>> point 2: 0.100000 0.000000
>>> point 3: 0.100000 2.500000
>>> As you can see instead of going around the perimeter of the cell the
>>> path from 1 to 2 instead bisects the cell.
>>> I can manually reorder these after I read in the coordinates by manually
>>> checking right-handedness but I was wondering if there is an easier way to
>>> reorder the cones? If there isn't once I do reorder the cones manually is
>>> there anything I need to do as far as station keeping on the DM?
>> The function DMPlexOrient() reorders the cones so that all cells have
>> compatible orientation. However, it will not catch this because it is
>> an illegal ordering for a quad. This order is called
>> a DM_POLYTOPE_SEG_PRISM_TENSOR in Plex because it is the tensor product of
>> two segments (so that opposite sides have the same orientation). If all
>> your cells are this way, you can just mark them as tensor segments
>> and you are done. If only some turn out this way, then we have to write
>> some code to recognize them, or flip them when you create the cones.
>>   Thanks,
>>     Matt
>>> I apologize if I missed any resources on this.
>>> Thanks
>>> Nicholas
>>> Ph.D. Candidate
>>> Computational Aeroscience Lab
>>> University of Michigan
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> Ph.D. Candidate
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230208/27bdafa6/attachment.html>
