[petsc-users] interpreting data from SNESSolve profiling
    Matteo Semplice
    matteo.semplice at uninsubria.it
    Wed Feb  8 06:56:23 CST 2023
Dear all,
     I am trying to optimize the nonlinear solvers in a code of mine,
but I am having a hard time at interpreting the profiling data from the
SNES. In particular, if I run with -snesCorr_snes_lag_jacobian 5
-snesCorr_snes_linesearch_monitor -snesCorr_snes_monitor
-snesCorr_snes_linesearch_type basic -snesCorr_snes_view I get, for all
timesteps an output like
0 SNES Function norm 2.204257292307e+00
  1 SNES Function norm 5.156376709750e-03
  2 SNES Function norm 9.399026338316e-05
  3 SNES Function norm 1.700505246874e-06
  4 SNES Function norm 2.938127043559e-08
SNES Object: snesCorr (snesCorr_) 1 MPI process
  type: newtonls
  maximum iterations=50, maximum function evaluations=10000
  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
  total number of linear solver iterations=4
  total number of function evaluations=5
  norm schedule ALWAYS
  Jacobian is rebuilt every 5 SNES iterations
  SNESLineSearch Object: (snesCorr_) 1 MPI process
    type: basic
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
    maximum iterations=40
  KSP Object: (snesCorr_) 1 MPI process
    type: gmres
      restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
      happy breakdown tolerance 1e-30
    maximum iterations=10000, initial guess is zero
    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
    left preconditioning
    using PRECONDITIONED norm type for convergence test
  PC Object: (snesCorr_) 1 MPI process
    type: ilu
      out-of-place factorization
      0 levels of fill
      tolerance for zero pivot 2.22045e-14
      matrix ordering: natural
      factor fill ratio given 1., needed 1.
        Factored matrix follows:
          Mat Object: (snesCorr_) 1 MPI process
            type: seqaij
            rows=1200, cols=1200
            package used to perform factorization: petsc
            total: nonzeros=17946, allocated nonzeros=17946
              using I-node routines: found 400 nodes, limit used is 5
    linear system matrix = precond matrix:
    Mat Object: 1 MPI process
      type: seqaij
      total number of mallocs used during MatSetValues calls=0
I guess that this means that no linesearch is performed and the full
Newton step is always performed (I did not report the full output, but
all timesteps are alike). Also, with the default (bt) LineSearch, the
total CPU time does not change, which seems in line with this.
However, I'd have expected that the time spent in SNESLineSearch would
be negligible, but the flamegraph is showing that about 38% of the time
spent by SNESSolve is actually spent in SNESLineSearch. Furthermore,
SNESLineSearch seems to cause more SNESFunction evaluations (in terms of
CPU time) than the SNESSolve itself. The flamegraph is attached.
Could some expert help me in understanding these data? Is the LineSearch
actually performing the newton step? Given that the full step is always
taken, can the SNESFunction evaluations from the LineSearch be skipped?
Thanks a lot!
Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230208/14f71c48/attachment-0001.html>
Type: image/svg+xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230208/14f71c48/attachment-0001.svg>
