[petsc-users] Question about MatGetRow
    김성익
    ksi2443 at gmail.com
    Fri Feb  3 07:06:22 CST 2023
Following your comments,
I want to check below things.
For example, the global dense matrix are as below.
[image: image.png]
If I want to get first row ('1 2 0 0 3 0 0 4') in Proc 1.
Then I should put 'MatCreateSubMatrix
<https://petsc.org/main/docs/manualpages/Mat/MatCreateSubMatrix/>(mat, isrow
, NULL, MAT_INITIAL_MATRIX, *&*newmat)'
and isrow will be [0 1 2 3 4 5 6 7].
In this case, How can I make isrow?
Actually I can't understand the procedure of handling isrow.
Hyung Kim
2023년 2월 3일 (금) 오후 9:03, Mark Adams <mfadams at lbl.gov>님이 작성:
> Note, PETSc lets you give NULL arguments if there is a reasonable default.
> In this case give NULL for the column IS and you will get the whole
> columns.
> Mark
> On Fri, Feb 3, 2023 at 4:05 AM 김성익 <ksi2443 at gmail.com> wrote:
>> Hello,
>> By using MatGetRow, user can get vectors from local matrix (at each
>> process).
>> However, I need other process's row values.
>> So I have 2 questions.
>> 1. Is there any function for getting arrays from other process's??
>> 2. Or is there any function like matrix version of vecscattertoall??
>> Thanks,
>> Hyung Kim
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/382dc0f7/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/382dc0f7/attachment-0001.png>
