[petsc-users] Question about MatGetRow
Mark Adams
mfadams at lbl.gov
Fri Feb 3 06:03:19 CST 2023
https://petsc.org/main/docs/manualpages/Mat/MatCreateSubMatrix/
Note, PETSc lets you give NULL arguments if there is a reasonable default.
In this case give NULL for the column IS and you will get the whole columns.
On Fri, Feb 3, 2023 at 4:05 AM 김성익 <ksi2443 at gmail.com> wrote:
> Hello,
> By using MatGetRow, user can get vectors from local matrix (at each
> process).
> However, I need other process's row values.
> So I have 2 questions.
> 1. Is there any function for getting arrays from other process's??
> 2. Or is there any function like matrix version of vecscattertoall??
> Thanks,
> Hyung Kim
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/019b643c/attachment.html>
