[petsc-users] Help with Integrating PETSc into Fortran Groundwater Flow Simulation Code
Wed Dec 20 20:54:33 CST 2023
On Wed, Dec 20, 2023 at 9:49 PM Shatanawi, Sawsan Muhammad via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello Barry,
> Thank you a lot for your help, Now I am getting the attached error message.
Do not destroy the PC from KSPGetPC()
  THanks,
     Matt
> Bests,
> Sawsan
> *From:* Barry Smith <bsmith at petsc.dev>
> *Sent:* Wednesday, December 20, 2023 6:32 PM
> *To:* Shatanawi, Sawsan Muhammad <sawsan.shatanawi at wsu.edu>
> *Cc:* Mark Adams <mfadams at lbl.gov>; petsc-users at mcs.anl.gov <
> *Subject:* Re: [petsc-users] Help with Integrating PETSc into Fortran
> *[EXTERNAL EMAIL]*
> Instead of
>     call PCCreate(PETSC_COMM_WORLD, pc, ierr)
>     call PCSetType(pc, PCILU,ierr) ! Choose a preconditioner type (ILU)
>     call KSPSetPC(ksp, pc,ierr)  ! Associate the preconditioner with the
> KSP solver
> do
>     call KSPGetPC(ksp,pc,ierr)
> Do not call KSPSetUp(). It will be taken care of automatically during the
> solve
> On Dec 20, 2023, at 8:52 PM, Shatanawi, Sawsan Muhammad via petsc-users <
> Hello,
> I don't think that I set preallocation values when I created the matrix,
> would you please have look at my code. It is just the petsc related part
> from my code.
> I was able to fix some of the error messages. Now I have a new set of
> error messages related to the KSP solver (attached)
> I appreciate your help
> Sawsan
> *From:* Mark Adams <mfadams at lbl.gov>
> *Sent:* Wednesday, December 20, 2023 6:44 AM
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *[EXTERNAL EMAIL]*
> Did you set preallocation values when you created the matrix?
> Don't do that.
> On Wed, Dec 20, 2023 at 9:36 AM Shatanawi, Sawsan Muhammad <
> sawsan.shatanawi at wsu.edu> wrote:
> Hello,
> I am trying to create a sparse matrix( which is as I believe a zero
> matrix) then adding some nonzero elements to it over a loop, then
> assembling it
> Get Outlook for iOS
> <https://urldefense.com/v3/__https://aka.ms/o0ukef__;!!JmPEgBY0HMszNaDT!uUJ_jeYf45gcXDGR_PeMjhU7hbd_fKcXJPn0pM9eb-YQihKNYuXMYM9x-hglsbXsCFIwNBWgHXdetHODupsOloE$>
> *Sent:* Wednesday, December 20, 2023 2:48 AM
> *[EXTERNAL EMAIL]*
> I am guessing that you are creating a matrix, adding to it, finalizing it
> ("assembly"), and then adding to it again, which is fine, but you are
> adding new non-zeros to the sparsity pattern.
> If this is what you want then you can tell the matrix to let you do that.
> Otherwise you have a bug.
> Mark
> On Tue, Dec 19, 2023 at 9:50 PM Shatanawi, Sawsan Muhammad via petsc-users
> <petsc-users at mcs.anl.gov> wrote:
> Hello everyone,
> I hope this email finds you well.
>  My Name is Sawsan Shatanawi, and I am currently working on developing a
> Fortran code for simulating groundwater flow in a 3D system. The code
> involves solving a nonlinear system, and I have created the matrix to be
> solved using the PCG solver and Picard iteration. However, when I tried
> to assign it as a PETSc matrix I started getting a lot of error messages.
> I am kindly asking if someone can help me, I would be happy to share my
> code with him/her.
> Please find the attached file contains a list of errors I have gotten
> Thank you in advance for your time and assistance.
> Best regards,
>  Sawsan
> <Matrix_RHS.F90><out.txt><solver.F90>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231220/a5eed63c/attachment.html>
