[petsc-users] Help with Integrating PETSc into Fortran Groundwater Flow Simulation Code
Shatanawi, Sawsan Muhammad
sawsan.shatanawi at wsu.edu
Wed Dec 20 20:49:13 CST 2023
Hello Barry,
Thank you a lot for your help, Now I am getting the attached error message.
Bests,
Sawsan
Sent: Wednesday, December 20, 2023 6:32 PM
To: Shatanawi, Sawsan Muhammad <sawsan.shatanawi at wsu.edu>
Cc: Mark Adams <mfadams at lbl.gov>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Help with Integrating PETSc into Fortran Groundwater Flow Simulation Code
[EXTERNAL EMAIL]
Instead of
call PCCreate(PETSC_COMM_WORLD, pc, ierr)
call PCSetType(pc, PCILU,ierr) ! Choose a preconditioner type (ILU)
call KSPSetPC(ksp, pc,ierr) ! Associate the preconditioner with the KSP solver
do
call KSPGetPC(ksp,pc,ierr)
Do not call KSPSetUp(). It will be taken care of automatically during the solve
On Dec 20, 2023, at 8:52 PM, Shatanawi, Sawsan Muhammad via petsc-users <petsc-users at mcs.anl.gov> wrote:
Hello,
I don't think that I set preallocation values when I created the matrix, would you please have look at my code. It is just the petsc related part from my code.
I was able to fix some of the error messages. Now I have a new set of error messages related to the KSP solver (attached)
I appreciate your help
Sawsan
From: Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>>
Sent: Wednesday, December 20, 2023 6:44 AM
To: Shatanawi, Sawsan Muhammad <sawsan.shatanawi at wsu.edu<mailto:sawsan.shatanawi at wsu.edu>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
[EXTERNAL EMAIL]
Did you set preallocation values when you created the matrix?
Don't do that.
On Wed, Dec 20, 2023 at 9:36 AM Shatanawi, Sawsan Muhammad <sawsan.shatanawi at wsu.edu<mailto:sawsan.shatanawi at wsu.edu>> wrote:
Hello,
I am trying to create a sparse matrix( which is as I believe a zero matrix) then adding some nonzero elements to it over a loop, then assembling it
Get Outlook for iOS<https://urldefense.com/v3/__https://aka.ms/o0ukef__;!!JmPEgBY0HMszNaDT!uUJ_jeYf45gcXDGR_PeMjhU7hbd_fKcXJPn0pM9eb-YQihKNYuXMYM9x-hglsbXsCFIwNBWgHXdetHODupsOloE$>
Sent: Wednesday, December 20, 2023 2:48 AM
[EXTERNAL EMAIL]
I am guessing that you are creating a matrix, adding to it, finalizing it ("assembly"), and then adding to it again, which is fine, but you are adding new non-zeros to the sparsity pattern.
If this is what you want then you can tell the matrix to let you do that.
Otherwise you have a bug.
On Tue, Dec 19, 2023 at 9:50 PM Shatanawi, Sawsan Muhammad via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello everyone,
I hope this email finds you well.
My Name is Sawsan Shatanawi, and I am currently working on developing a Fortran code for simulating groundwater flow in a 3D system. The code involves solving a nonlinear system, and I have created the matrix to be solved using the PCG solver and Picard iteration. However, when I tried to assign it as a PETSc matrix I started getting a lot of error messages.
I am kindly asking if someone can help me, I would be happy to share my code with him/her.
Please find the attached file contains a list of errors I have gotten
Thank you in advance for your time and assistance.
Best regards,
Sawsan
<Matrix_RHS.F90><out.txt><solver.F90>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231221/bcdfdf6a/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231221/bcdfdf6a/attachment-0001.txt>
