[petsc-users] difference in Face Sets in latest petsc release
Sharan Roongta s.roongta at mpie.de
Tue Dec 12 18:13:02 CST 2023
Thanks for the clarification.
However, would it be more consistent to differentiate between 0D (vertex sets), 1D (edge sets), 2d (faces) and 3D (cell sets)?
If I want to now apply boundary condition on a face with tag 1, it would contain the 4 edges making up that face and an additional edge with the same physical tag?
Basically, I can’t differentiate between the two entities
Sharan
Group - Theory & Simulation
Department of Microstructure Physics & Alloy Design
 To:   Sharan Roongta <s.roongta at mpie.de>
 Cc:   "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
 Sent:   13/12/2023 12:51 AM
 Subject:   Re: [petsc-users] difference in Face Sets in latest petsc release
On Tue, Dec 12, 2023 at 5:50 PM Sharan Roongta <s.roongta at mpie.de> wrote:
Hello,
I see discrepancy in the size/value of the 'Face Sets' printed in the current release v3.20.2 , and v3.18.6
Attached is the .msh file
-dm_view with v3.18.6
DM Object: Generated Mesh 1 MPI process
  type: plex
Generated Mesh in 3 dimensions:
  Number of 0-cells per rank: 14
  Number of 1-cells per rank: 49
  Number of 2-cells per rank: 60
  Number of 3-cells per rank: 24
Labels:
  celltype: 4 strata with value/size (0 (14), 6 (24), 3 (60), 1 (49))
  depth: 4 strata with value/size (0 (14), 1 (49), 2 (60), 3 (24))
  Cell Sets: 1 strata with value/size (1 (24))
  Face Sets: 5 strata with value/size (1 (4), 2 (4), 3 (4), 4 (4), 5 (4))
-dm_view with the current release (commit 4b9a870af96)
  type: plex
Labels:
  Face Sets: 12 strata with value/size (1 (5), 2 (5), 3 (5), 4 (5), 5 (5), 6 (1), 7 (1), 8 (1), 9 (1), 10 (1), 11 (1), 12 (1))
I believe the older version printed the correct thing? Has something changed in the interpretation of Face Sets?
Yes. In the older version, I was only labeling cells, faces, and vertices. There were complaints, so I put in the edge labels. If you check, all the additional labels are on edges, and checking your .msh file, those edges clearly have those labels.
     Matt
Sharan
 Stay up to date and follow us on LinkedIn, Twitter and YouTube.
 Max-Planck-Institut für Eisenforschung GmbH
 Max-Planck-Straße 1
 D-40237 Düsseldorf
 Handelsregister B 2533
 Amtsgericht Düsseldorf
 Geschäftsführung
 Prof. Dr. Gerhard Dehm
 Prof. Dr. Jörg Neugebauer
 Prof. Dr. Dierk Raabe
 Dr. Kai de Weldige
 Ust.-Id.-Nr.: DE 11 93 58 514
 Steuernummer: 105 5891 1000
 Please consider that invitations and e-mails of our institute are
 only valid if they end with …@mpie.de.
 If you are not sure of the validity please contact rco at mpie.de
 Bitte beachten Sie, dass Einladungen zu Veranstaltungen und E-Mails
 aus unserem Haus nur mit der Endung …@mpie.de gültig sind.
 In Zweifelsfällen wenden Sie sich bitte an rco at mpie.de
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/
Max-Planck-Straße 1
D-40237 Düsseldorf
Geschäftsführung
Dr. Kai de Weldige
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231213/1e2e4e35/attachment.html>
