[petsc-users] Configure error while building PETSc with CUDA/MVAPICH2-GDR
Fri Dec 8 13:00:33 CST 2023
On Fri, Dec 8, 2023 at 1:54 PM Sreeram R Venkat <srvenkat at utexas.edu> wrote:
> I am trying to build PETSc with CUDA using the CUDA-Aware MVAPICH2-GDR.
> Here is my configure command:
> ./configure PETSC_ARCH=linux-c-debug-mvapich2-gdr --download-hypre
>  --with-cuda=true --cuda-dir=$TACC_CUDA_DIR --with-hdf5=true
> --with-hdf5-dir=$TACC_PHDF5_DIR --download-elemental --download-metis
> --download-parmetis --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
> which errors with:
>           UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
>   CUDA compile failed with arch flags " -ccbin mpic++ -std=c++14
> -Xcompiler -fPIC
>   -Xcompiler -fvisibility=hidden -g -lineinfo -gencode
> arch=compute_80,code=sm_80"
>   generated from "--with-cuda-arch=80"
> The same configure command works when I use the Intel MPI and I can build
> with CUDA. The full config.log file is attached. Please let me know if you
> need any other information. I appreciate your help with this.
The proximate error is
Executing: nvcc -c -o /tmp/petsc-kn3f29gl/config.packages.cuda/conftest.o
-I/tmp/petsc-kn3f29gl/config.setCompilers
-I/tmp/petsc-kn3f29gl/config.types
-I/tmp/petsc-kn3f29gl/config.packages.cuda  -ccbin mpic++ -std=c++14
-Xcompiler -fPIC -Xcompiler -fvisibility=hidden -g -lineinfo -gencode
arch=compute_80,code=sm_80  /tmp/petsc-kn3f29gl/config.packages.cuda/
conftest.cu
stdout:
/opt/apps/cuda/11.4/include/crt/sm_80_rt.hpp(141): error: more than one
instance of overloaded function "__nv_associate_access_property_impl" has
"C" linkage
1 error detected in the compilation of
"/tmp/petsc-kn3f29gl/config.packages.cuda/conftest.cu".
Possible ERROR while running compiler: exit code 1
stderr:
"C" linkage
This looks like screwed up headers to me, but I will let someone that
understands CUDA compilation reply.
     Matt
> Sreeram
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231208/6ef8870a/attachment.html>
