[petsc-users] Configure GPU for Apple M1 chip
Jacob Faibussowitsch
jacob.fai at gmail.com
Fri Apr 21 14:53:22 CDT 2023
> How do I configure PETSc to use gpu on buy Mac powerbook where the gpu is integrated into the Apple M1 chip?
PETSc does not currently support metal. Our GPU support is currently limited to CUDA, HIP, and SYCL.
> I do I need to install a clang compiler?
macOS comes with a clang compiler installed, but if you want to ensure one is installed you can run `xcode-select --install`.
Best regards,
(Jacob Fai - booss - oh - vitch)
> Do I need to download the Apple developer Metal toolkit, and I do I need to install a clang compiler?
> -Roger
