[petsc-users] Setting up a matrix for Lagrange multiplier
Karthikeyan Chockalingam - STFC UKRI karthikeyan.chockalingam at stfc.ac.uk
Tue Apr 18 10:16:46 CDT 2023
Thank you for your response. I spend some time understanding how
MatSetValuesLocal and ISLocalToGlobalMappingCreate work.
Q1) Will the matrix K be of type MATMPIAIJ or MATIS?
K = [A P^T
       P   0]
Q2) Can I use both MatSetValues() to MatSetValuesLocal() to populate K? Since I have already used MatSetValues() to construct A.
Q3) What are the advantages of using MatSetValuesLocal()? Is it that I can construct P directly using local indies and map the entrees to the global index in K?
Q4) I probably don’t have to construct an independent P matrix?
Best regards,
Karthik.
Date: Tuesday, 18 April 2023 at 11:08
To: Chockalingam, Karthikeyan (STFC,DL,HC) <karthikeyan.chockalingam at stfc.ac.uk>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Setting up a matrix for Lagrange multiplier
On Tue, Apr 18, 2023 at 5:24 AM Karthikeyan Chockalingam - STFC UKRI via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello,
I'm solving a problem using the Lagrange multiplier, the matrix has the form
K = [A P^T
       P   0]
I am familiar with constructing K using MATMPIAIJ. However, I would like to know if had [A], can I augment it with [P], [P^T] and [0] of type MATMPIAIJ? Likewise for vectors as well.
Can you please point me to the right resource, if it is a common operation in PETSc?
You can do this at least 2 ways:
  1) Assemble you submatrices directly into the larger matrix by constructing local-to-global maps for the emplacement. so that you do
      not change your assembly code, except to change MatSetValues() to MatSetValuesLocal(). This is usually preferable.
  2) Use MATNEST and VecNEST to put pointers to submatrices and subvectors directly in.
     Matt
Many thanks.
Kind regards,
Karthik.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230418/b8763c29/attachment-0001.html>
