[petsc-users] Setting up a matrix for Lagrange multiplier
Tue Apr 18 05:08:03 CDT 2023
On Tue, Apr 18, 2023 at 5:24 AM Karthikeyan Chockalingam - STFC UKRI via
petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello,
> I'm solving a problem using the Lagrange multiplier, the matrix has the
> form
> K = [A P^T
>        P   0]
> I am familiar with constructing K using MATMPIAIJ. However, I would like
> to know if had [A], can I augment it with [P], [P^T] and [0] of type
> MATMPIAIJ? Likewise for vectors as well.
> Can you please point me to the right resource, if it is a common operation
> in PETSc?
You can do this at least 2 ways:
  1) Assemble you submatrices directly into the larger matrix by
constructing local-to-global maps for the emplacement. so that you do
      not change your assembly code, except to change MatSetValues() to
MatSetValuesLocal(). This is usually preferable.
  2) Use MATNEST and VecNEST to put pointers to submatrices and subvectors
directly in.
     Matt
> Many thanks.
> Kind regards,
> Karthik.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230418/21b5556c/attachment.html>
