[petsc-users] MPI linear solver reproducibility question
Jed Brown jed at jedbrown.org
Sat Apr 1 23:05:16 CDT 2023
If you use unpreconditioned BCGS and ensure that you assemble the same matrix (depends how you do the communication for that), I think you'll get bitwise reproducible results when using an MPI that follows the suggestion for implementers about determinism. Beyond that, it'll depend somewhat on the preconditioner.
If you like BCGS, you may want to try BCGSL, which has a longer memory and tends to be more robust. But preconditioning is usually critical and the place to devote most effort.
Mark McClure <mark at resfrac.com> writes:
> Hello,
> I have been a user of Petsc for quite a few years, though I haven't updated
> my version in a few years, so it's possible that my comments below could be
> 'out of date'.
> Several years ago, I'd asked you guys about reproducibility. I observed
> that if I gave an identical matrix to the Petsc linear solver, I would get
> a bit-wise identical result back if running on one processor, but if I ran
> with MPI, I would see differences at the final sig figs, below the
> convergence criterion. Even if rerunning the same exact calculation on the
> same exact machine.
> Ie, with repeated tests, it was always converging to the same answer
> 'within convergence tolerance', but not consistent in the sig figs beyond
> the convergence tolerance.
> At the time, the response that this was unavoidable, and related to the
> issue that machine arithmetic is not commutative, and so the timing of when
> processors were recombining information (which was random, effectively a
> race condition) was causing these differences.
> Am I remembering correctly? And, if so, is this still a property of the
> Petsc linear solver with MPI, and is there now any option available to
> resolve it? I would be willing to accept a performance hit in order to get
> guaranteed bitwise consistency, even when running with MPI.
> I am using the solver KSPBCGS, without a preconditioner. This is the
> selection because several years ago, I did testing, and found that on the
> particular linear systems that I am usually working with, this solver (with
> no preconditioner) was the most robust, in terms of consistently
> converging, and in terms of performance. Actually, I also tested a variety
> of other linear solvers other than Petsc (including other implementations
> of BiCGStab), and found that the Petsc BCGS was the best performer. Though,
> I'm curious, have there been updates to that algorithm in recent years,
> where I should consider updating to a newer Petsc build and comparing?
> Best regards,
> Mark McClure
