[petsc-users] Solve Linear System with Field Split Preconditioner
    晓峰 何
    tlanyan at hotmail.com
    Tue Sep 27 09:23:41 CDT 2022
Many thanks for your concrete replies. They are very helpful.
Best Wishes,
Xiaofeng
On Sep 27, 2022, at 20:01, Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>> wrote:
Shells can be pretty hard.
Start with an easy problem with well-shaped elements and probably best to start with a well-supported structure (eg, not a long cantilever).
You should also configure with hypre and try that. I don't know if they deal with shells, but it is a well developed solver.
For GAMG, you need to set the coordinates (PCSetCoordinates) which will create the rigid body modes for GAMG so that it can construct the rotational RBMs.
This code has not been used for shells in a long time (petsc/src/ksp/pc/impls/gamg/agg.c:138), but it did once work (20 years ago in another code).
This code constructs the 6 rigid body modes for 3D shell problems with my ording (6 dof, x,y,z,xx,yy,zz).
Or you can construct the RBMs yourself and set them with https://petsc.org/release/docs/manualpages/Mat/MatNullSpaceCreateRigidBody.html
There is some discussion here: https://www2.eecs.berkeley.edu/Pubs/TechRpts/2000/CSD-00-1103.pdf
On Tue, Sep 27, 2022 at 6:20 AM 晓峰 何 <tlanyan at hotmail.com<mailto:tlanyan at hotmail.com>> wrote:
Hello,
A00 comes from shell structures and discretized by FEM.
Xiaofeng
On Sep 27, 2022, at 17:48, Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>> wrote:
what equations and discetizations are in A00?
On Tue, Sep 27, 2022 at 1:45 AM 晓峰 何 <tlanyan at hotmail.com<mailto:tlanyan at hotmail.com>> wrote:
Hi Barry,
A00 is formed from elliptic operator.
I tried GAMG with A00, but it was extremely slow to solve the system with field-split preconditioner(I’m not sure I did it with the right way).
Xiaofeng
On Sep 26, 2022, at 23:11, Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>> wrote:
  What is your A00 operator? ILU is almost never a good choice for large scale problems. If it is an elliptic operator that using a PC of gamg may work well for the A00 preconditioner instead of ILU.
  Barry
  For moderate size problems you can use a PC type LU for AOO to help you understand the best preconditioner to use for the A11 (the Schur complement block), once you have a good preconditioner for the A11 block you would then go back and determine a good preconditioner for the A00 block.
On Sep 26, 2022, at 10:08 AM, 晓峰 何 <tlanyan at hotmail.com<mailto:tlanyan at hotmail.com>> wrote:
Hello Jed,
The saddle point is due to Lagrange multipliers, thus the size of A11 is much smaller than A00.
Best Regards,
Xiaofeng
On Sep 26, 2022, at 21:03, Jed Brown <jed at jedbrown.org<mailto:jed at jedbrown.org>> wrote:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220927/c7ea1602/attachment-0001.html>
