[petsc-users] Solve Linear System with Field Split Preconditioner
Barry Smith
bsmith at petsc.dev
Mon Sep 26 10:11:57 CDT 2022
What is your A00 operator? ILU is almost never a good choice for large scale problems. If it is an elliptic operator that using a PC of gamg may work well for the A00 preconditioner instead of ILU.
Barry
For moderate size problems you can use a PC type LU for AOO to help you understand the best preconditioner to use for the A11 (the Schur complement block), once you have a good preconditioner for the A11 block you would then go back and determine a good preconditioner for the A00 block.
> On Sep 26, 2022, at 10:08 AM, 晓峰 何 <tlanyan at hotmail.com> wrote:
> Hello Jed,
> The saddle point is due to Lagrange multipliers, thus the size of A11 is much smaller than A00.
> Best Regards,
> Xiaofeng
>> On Sep 26, 2022, at 21:03, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220926/d3327667/attachment.html>
