[petsc-users] Solve Linear System with Field Split Preconditioner
Jed Brown jed at jedbrown.org
Mon Sep 26 08:03:07 CDT 2022
Xiaofeng, is your saddle point due to incompressibility or other constraints (like Lagrange multipliers for contact or multi-point constraints)? If incompressibility, are you working on structured or unstructured/non-nested meshes?
Matthew Knepley <knepley at gmail.com> writes:
> Another option are the PCPATCH solvers for multigrid, as shown in this
> paper: https://arxiv.org/abs/1912.08516
> which I believe solves incompressible elasticity. There is an example in
> PETSc for Stokes I believe.
>   Thanks,
>      Matt
> On Mon, Sep 26, 2022 at 5:20 AM 晓峰 何 <tlanyan at hotmail.com> wrote:
>> Are there other approaches to solve this kind of systems in PETSc except
>> for field-split methods?
>> Thanks,
>> Xiaofeng
>> On Sep 26, 2022, at 14:13, Jed Brown <jed at jedbrown.org> wrote:
>> This is the joy of factorization field-split methods. The actual Schur
>> complement is dense, so we represent it implicitly. A common strategy is to
>> assemble the mass matrix and drop it in the 11 block of the Pmat. You can
>> check out some examples in the repository for incompressible flow (Stokes
>> problems). The LSC (least squares commutator) is another option. You'll
>> likely find that lumping diag(A00)^{-1} works poorly because the resulting
>> operator behaves like a Laplacian rather than like a mass matrix.
>> 晓峰 何 <tlanyan at hotmail.com> writes:
>> If assigned a preconditioner to A11 with this cmd options:
>>   -fieldsplit_0_ksp_type gmres -fieldsplit_0_pc_type ilu
>> -fieldsplit_1_ksp_type gmres -fieldsplit_1_pc_type ilu
>> Then I got this error:
>> "Could not locate a solver type for factorization type ILU and matrix type
>> schurcomplement"
>> How could I specify a preconditioner for A11?
>> BR,
>> Xiaofeng
>> On Sep 26, 2022, at 11:02, 晓峰 何 <tlanyan at hotmail.com<
>> -fieldsplit_1_ksp_type gmres -fieldsplit_1_pc_type none
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
