[petsc-users] Solve Linear System with Field Split Preconditioner
Mon Sep 26 07:29:33 CDT 2022
Another option are the PCPATCH solvers for multigrid, as shown in this
paper: https://arxiv.org/abs/1912.08516
which I believe solves incompressible elasticity. There is an example in
PETSc for Stokes I believe.
     Matt
On Mon, Sep 26, 2022 at 5:20 AM 晓峰 何 <tlanyan at hotmail.com> wrote:
> Are there other approaches to solve this kind of systems in PETSc except
> for field-split methods?
> Thanks,
> Xiaofeng
> On Sep 26, 2022, at 14:13, Jed Brown <jed at jedbrown.org> wrote:
> This is the joy of factorization field-split methods. The actual Schur
> complement is dense, so we represent it implicitly. A common strategy is to
> assemble the mass matrix and drop it in the 11 block of the Pmat. You can
> check out some examples in the repository for incompressible flow (Stokes
> problems). The LSC (least squares commutator) is another option. You'll
> likely find that lumping diag(A00)^{-1} works poorly because the resulting
> operator behaves like a Laplacian rather than like a mass matrix.
> 晓峰 何 <tlanyan at hotmail.com> writes:
> If assigned a preconditioner to A11 with this cmd options:
>   -fieldsplit_0_ksp_type gmres -fieldsplit_0_pc_type ilu
> -fieldsplit_1_ksp_type gmres -fieldsplit_1_pc_type ilu
> Then I got this error:
> "Could not locate a solver type for factorization type ILU and matrix type
> schurcomplement"
> How could I specify a preconditioner for A11?
> BR,
> Xiaofeng
> On Sep 26, 2022, at 11:02, 晓峰 何 <tlanyan at hotmail.com<
> -fieldsplit_1_ksp_type gmres -fieldsplit_1_pc_type none
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220926/369b03c4/attachment-0001.html>
