[petsc-users] Solve Linear System with Field Split Preconditioner
Jed Brown
jed at jedbrown.org
Mon Sep 26 01:13:18 CDT 2022
This is the joy of factorization field-split methods. The actual Schur complement is dense, so we represent it implicitly. A common strategy is to assemble the mass matrix and drop it in the 11 block of the Pmat. You can check out some examples in the repository for incompressible flow (Stokes problems). The LSC (least squares commutator) is another option. You'll likely find that lumping diag(A00)^{-1} works poorly because the resulting operator behaves like a Laplacian rather than like a mass matrix.
晓峰 何 <tlanyan at hotmail.com> writes:
> If assigned a preconditioner to A11 with this cmd options:
> -fieldsplit_0_ksp_type gmres -fieldsplit_0_pc_type ilu -fieldsplit_1_ksp_type gmres -fieldsplit_1_pc_type ilu
> Then I got this error:
> "Could not locate a solver type for factorization type ILU and matrix type schurcomplement"
> How could I specify a preconditioner for A11?
> BR,
> Xiaofeng
> On Sep 26, 2022, at 11:02, 晓峰 何 <tlanyan at hotmail.com<mailto:tlanyan at hotmail.com>> wrote:
> -fieldsplit_0_ksp_type gmres -fieldsplit_0_pc_type ilu -fieldsplit_1_ksp_type gmres -fieldsplit_1_pc_type none
