[petsc-users] KSP on GPU
Barry Smith
bsmith at petsc.dev
Mon Oct 31 09:06:36 CDT 2022
Please send the full output when you run with the monitors I mentioned turned on. If one approach is converging and one is not then we should be able to see this in differences in the convergence output printed for the two runs getting further and further apart.
Barry
> On Oct 31, 2022, at 1:56 AM, Carl-Johan Thore <carl-johan.thore at liu.se> wrote:
> The GPU supports double precision and I didn’t explicitly tell PETSc to use float when compiling, so
> I guess it uses double? What’s the easiest way to check?
> Barry, running -ksp_view shows that the solver options are the same for CPU and GPU. The only
> difference is the coarse grid solver for gamg (“the package used to perform factorization:”) which
> is petsc for CPU and cusparse for GPU. I tried forcing the GPU to use petsc via
> -fieldsplit_0_mg_coarse_sub_pc_factor_mat_solver_type, but then ksp failed to converge
> even on the first topology optimization iteration.
> -ksp_view also shows differences in the eigenvalues from the Chebyshev smoother. For example,
> GPU:
> Down solver (pre-smoother) on level 2 -------------------------------
> KSP Object: (fieldsplit_0_mg_levels_2_) 1 MPI process
> type: chebyshev
> eigenvalue targets used: min 0.109245, max 1.2017
> eigenvalues provided (min 0.889134, max 1.09245) with
> CPU:
> eigenvalue targets used: min 0.112623, max 1.23886
> eigenvalues provided (min 0.879582, max 1.12623)
> But I guess such differences are expected?
> /Carl-Johan
> From: Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>
> Sent: den 30 oktober 2022 22:00
> To: Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>
> Cc: Carl-Johan Thore <carl-johan.thore at liu.se <mailto:carl-johan.thore at liu.se>>; petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] KSP on GPU
> On Sun, Oct 30, 2022 at 3:52 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
> In general you should expect similar but not identical conference behavior.
> I suggest running with all the monitoring you can. -ksp_monitor_true_residual -fieldsplit_0_monitor_true_residual -fieldsplit_1_monitor_true_residual and compare the various convergence between the CPU and GPU. Also run with -ksp_view and check that the various solver options are the same (they should be).
> Is the GPU using float or double?
> Matt
> Barry
> On Oct 30, 2022, at 11:02 AM, Carl-Johan Thore via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> Hi,
> I'm solving a topology optimization problem with Stokes flow discretized by a stabilized Q1-Q0 finite element method
> and using BiCGStab with the fieldsplit preconditioner to solve the linear systems. The implementation
> is based on DMStag, runs on Ubuntu via WSL2, and works fine with PETSc-3.18.1 on multiple CPU cores and the following
> options for the preconditioner:
> -fieldsplit_0_ksp_type preonly \
> -fieldsplit_0_pc_type gamg \
> -fieldsplit_0_pc_gamg_reuse_interpolation 0 \
> -fieldsplit_1_ksp_type preonly \
> -fieldsplit_1_pc_type jacobi
> However, when I enable GPU computations by adding two options -
> -dm_vec_type cuda \
> -dm_mat_type aijcusparse \
> - KSP still works fine the first couple of topology optimization iterations but then
> stops with "Linear solve did not converge due to DIVERGED_DTOL ..".
> My question is whether I should expect the GPU versions of the linear solvers and pre-conditioners
> to function exactly as their CPU counterparts (I got this impression from the documentation),
> in which case I've probably made some mistake in my own code, or whether there are other/additional
> settings or modifications I should use to run on the GPU (an NVIDIA Quadro T2000)?
> Kind regards,
> Carl-Johan
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=05%7C01%7Ccarl-johan.thore%40liu.se%7C8113f968516a44cce6ba08dabab9b28e%7C913f18ec7f264c5fa816784fe9a58edd%7C0%7C0%7C638027603971893036%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=gQ45cdsgo404NeBzZ7e6c5zNXhYOy39ZPfZzqtGDaDk%3D&reserved=0>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221031/427a9ddc/attachment-0001.html>
